Chewed Wire
/ Chewed Wire #1
lakngulf
Lake Martin Alabama
Kioti CK30
I had to raise hood on CK30 to clean debris from radiator and noticed a pile of insulation and trash. I removed the trash and found that some wires had been chewed
Can I just wrap this up with tape and be good to go? Or should I look toward replacing?
/ Chewed Wire #2
I hate rodents!
If the wire is still intact you should be fine with just re-insulating. I’ve taped many bare wires up and haven’t really had any issues.
Now, something like a starter wire, yes I would replace it.
/ Chewed Wire #4
I would either splice on a new piece of wire or slide some heat shrink over it and shrink it. I don't trust tape to stay taped or glue to not degrade. On the other hand that wire probably just supplies a resisted ground signal so worse case is you would start reading full all the time if it shorts.
Just put new bags of moth balls in my generator and stuck one in the frame tube of my JD and one on top of the radiator of my backhoe. Had a mouse chewed through a return hose on the backhoe once. I replaced it and next time I went to use it he had done it again. I put some bait on the manifold for that one and put a stop to his shenanigans.
/ Chewed Wire #5
+1 on bait. It’s the only thing that seems to keep the little critters out of my stuff!
/ Chewed Wire
Well I see I put this on Kubota site instead of Kioti, but I guess the Rat is no respector of brands.
/ Chewed Wire #7
That's why mine gets garaged where my mousing crew sleeps. I don't even get spiders - those cats kill everything that moves and is smaller than them.
/ Chewed Wire #8
I've use rubber tape yet to have problem.
2008 HINO 268 4X2 S/A ARMORED TRUCK (A59910)
2008 HINO 268 4X2...
17109SFL (A61569)
17109SFL (A61569)
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
John Deere 2355 Tractor (A61166)
John Deere 2355...
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
