Cherry Picker for Boom Pole?
   / Cherry Picker for Boom Pole? #1
Superduper
Platinum Member
Somewhere, over the rainbow.
John Deere 3120, Kubota BX2350, Deere X740
I have been running this over in my mind for some time now. Will be needing a boompole and just don't like what I see being offered. Was wondering whether anyone ever investigated using old engine hoists (cherry pickers) and modifying them to work on the 3PH (or even FEL) for use as a boom pole. Most have good capacity and I imagine even the manual ram could be substituted with a hydraulic ram for automatic (lazy) operation.
Anyone ever done this? Any comments (pluses or minus) for why this might not work?
   / Cherry Picker for Boom Pole? #2
I don't know the lift of your machine but mine will lift 200 pounds 29 feet up easy. see attachment and this is not my actual boom, the NOW boom is much stronger :D
Jim
Jim
That'll work! Actually, my loader is rated at 1650lbs +/- lift but I don't need all of that capacity. I would like to be able to lift some beams (don't need reach, need height) to assist in building a future garage project. Last I looked, I didn't see your gizmo at the local TSC so I imagine it's custom all the way.
   / Cherry Picker for Boom Pole? #4
Yes, it's homemade all the way with a 4' main pole with a 3" inside, a little welding and you can be in business. And the best part is.. It's easy and mine will only lift 1,750 pounds
Jim
78 & 82 Vettes
   / Cherry Picker for Boom Pole? #5
I think this is what you are looking for. Had this 2 ton engine crane not doing any thing so decided to make use of it. All it took was to weld on hookup for top link (I have T&T), take it off of the crane base and bolt it onto a draw bar and away you go. If you want to get fancy then you can paint it your tractor color. ;) The T&T gives it more reach flexibility and the tilt gives you fine side to side adjustment. Now if you hook up hydraulic from tractor to crane cylinder that would be real sweet.:D
   / Cherry Picker for Boom Pole? #6
I really like waht mfrost did, and think the paint job is awesome. Really cool.
I took the bar off my cherry picker and bolted it through some holes I drilled into the side of my FEL. I don't think the holes cause any strength issues, but that's just a guess on my part.
I've lifted engines this way and carried them to my shop across rough ground, so do know it works very well.
The best part is that it only takes a few minutes to install or remove.
Eddie
   / Cherry Picker for Boom Pole? #7
There have been a few posts of folks welding a piece of 2" square tubing on the back of engine hoists and sliding them on a receiver mounted either on the bucket or 3ph. Very quick and easy. Could also plug it into the back of the truck.:cool:
   / Cherry Picker for Boom Pole? #8
Great idea!! ;)
   / Cherry Picker for Boom Pole? #9
I took a receiver hitch and cut the square receiver away with a torch.Then I welded it to the top of fel.2" square tubing is universal for alot of attachments.I made a 4 ft boom with a hook so I could take beds off of trucks by myself.If you'd like a picture let me know.
Mfrost, great job on yours!
   / Cherry Picker for Boom Pole? #10
Mine also has it's own receiver built in.
I just noticed these pics were before I added the reveiver to the bottom and widened to fit my VAC.
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2017 Massey Ferguson GC1705 Compact Tractor (RUNS) (A50774)
2017 Massey...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
