Tires Checking waterfilled tire pressures
/ Checking waterfilled tire pressures #1
KEROSENEDRVR
N. California
DK35
How do you check the tire pressure in a water filled tire and get an accurate reading? I seem to have a low tire but can't get an accurate reading with the tire in the 12 or 6 o'clock position.
/ Checking waterfilled tire pressures #2
I have a low preasure hydraulic gauge I use that I installed a tire chuck on to check water and anti-freeze filled tires with. You could make a cheap one by going to the hardware store and getting a water preasure gauge ment for water tanks and screwing a tire chuck onto it. Just make sure the gauge is rated for more preasure than the tire will have in it.
/ Checking waterfilled tire pressures #3
I've ruined a couple of pressure gauges with my CaCl filled tires. Now I just set the compressor regulator, rotate the wheel until the stem is a 12 oclock and see if it takes any air.
/ Checking waterfilled tire pressures #4
I like the idea checking with the liquid type gauge.:)
I have a ck25 with industrial tires and had the tires filled with the environmentally safe material when new. I have been wondering if anyone knows about how much weight the fluid adds to this tire? I know it's about
8 lbs a gallon, but ? the gallons.:confused:
Thanks
/ Checking waterfilled tire pressures #6
For Calcuim filled tires when you get the preasure gauge just make sure it's a totaly stainless steel gauge made for corrosive liquids. Problem solved.
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
Adams Weight Hopper (A63688)
Adams Weight...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
