checking rear
   / checking rear #1
Paul Luke
john deere 950
New here just got a jd 950 the left rear seems do do all the work How do I check to see whats up? thanks
   / checking rear #2
Why do you think the left rear is doing all the work? Does it pull to the right (going forward)?
First, try using your differential lock...both wheels pulling then?
Was it doing this when you tested the tractor (before you bought it)?
It's possible you have a rear brake sticking....might be better thread on the left tire. Or, might be nothing at all.
   / checking rear
thank you for the responce I tested it on pavement and it seemed fine in reverse in dirt the left digs and digs the diferential lock is broken off there is no foot petal ty
   / checking rear #4
I had a JD 950. The left always pushes until you engage the differential when pushing/ pulling heavy material.
FWIW, I use the differential only in dire need, or hardly ever.
Can you weld a new "L" piece on the broke diff. pedal arm? or better yet, get a new replacement.
   / checking rear #5
with the left spinning, step on the left brake if it has split brakes.. does it stop digging and you start moving magically?
if so.. your diffy is working as designed...
soundguy
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2- FREIGHTLINER BATTERY BOXES WITH BRACKETS (A53843)
2- FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
