checking hydro fluid on a B7800 Kubota
   / checking hydro fluid on a B7800 Kubota #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
Remove the dipstick from the tube. Check the end of the dipstick to see what the fluid level is. With the tractor engine off, the hydraulic fluid should register at the "Cold fill" line. If the fluid isn't at that level, you need to add more
What is the "cold fill " line ?
   / checking hydro fluid on a B7800 Kubota #2
Assuming you are talking about the transmission fluid level the fluid level is OK as long as it registers between the two ridges on the dipstick. Per my B7800 owners manual.
2014 AMERITRAIL, INC. TUGGER TRAILER (A50854)
2014 AMERITRAIL...
19009 (A48082)
19009 (A48082)
2010 Case 660 Trencher (A50322)
2010 Case 660...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
