checking hydro fluid on a B7800 Kubota
   / checking hydro fluid on a B7800 Kubota #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
Remove the dipstick from the tube. Check the end of the dipstick to see what the fluid level is. With the tractor engine off, the hydraulic fluid should register at the "Cold fill" line. If the fluid isn't at that level, you need to add more
What is the "cold fill " line ?
   / checking hydro fluid on a B7800 Kubota #2
Assuming you are talking about the transmission fluid level the fluid level is OK as long as it registers between the two ridges on the dipstick. Per my B7800 owners manual.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
197390 (A50459)
197390 (A50459)
71059 (A49346)
71059 (A49346)
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
1240 (A50490)
1240 (A50490)
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
