checking hydraulic oil level
   / checking hydraulic oil level #1
Mndigger
duluth Mn
TC5
I thought I posted this once but don't see it. What is the correct procedure for checking the oil level in the hydraulic system. If you screw in the oil fill dipstick you get one level and if you just rest the cap on top without screwing it in, the difference can be half way between the low level and full level.
   / checking hydraulic oil level #2
I check mine with the dip stick screwed in. As long as fluid is in between the low and high marks you are OK. I would expect that in units with larger capacities a little under or over the fill line is acceptable.
   / checking hydraulic oil level #3
You did - up in the Owning & Operating Section.
http://www.tractorbynet.com/forums/owning-operating/374219-terramite-tc5.html
I noticed it wasn't getting much attention there and was going to bump it & suggest posting here but you already have. :thumbsup:
Best of luck with your machine.
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
CAT 938B 2 Wheel Loader (A47384)
CAT 938B 2 Wheel...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
