Checking hydraulic level on ford 340A with front end loader
   / Checking hydraulic level on ford 340A with front end loader #1
Grey Mountain
Anadarko, Oklahoma
Ford 8N, Ford 340A
How do I check the fluid level on my 340A, and where do I add hydraulic fluid?
   / Checking hydraulic level on ford 340A with front end loader #2
my 540b has a vent on the left side of the loader upright. There is a dipstick below it and also where I add fluid
According to the specs, found the following:
Hydraulic system: 8.5 gal [32.2 L]
12.1 gal [45.8 L] (independent PTO)
What does "independent PTO mean?"
And more:
Rear PTO: transmission (optional)
independent (optional)
How do I determine if I have "transmission" or "independent?"
As you can see, I am a complete novice with this larger tractor. I understood my little 8N...
   / Checking hydraulic level on ford 340A with front end loader #4
You more than likely have independent PTO, every 340A I have ever seen did. Engage the PTO then push the clutch pedal fully down. If the PTO continues to turn you have IPTO.
The hydraulic system capacity you listed is for the tractor hydraulics / rear axle not the loader.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2004 CATERPILLAR 262B SKID STEER (A51246)
2004 CATERPILLAR...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
(1) RYOBI 212CC GENERATOR (A51248)
(1) RYOBI 212CC...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
