Checking air in loaded tires......Am I doing something wrong?
   / Checking air in loaded tires......Am I doing something wrong? #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I positioned the tires so the valve stem is at 12 o'clock. Took my handy dandy pressure gauge for ballasted tires and the fluid poured out of the stem as I applied the gauge, and couldn't get a reading. Are my tires filled to much? Or am I doing something wrong?
   / Checking air in loaded tires......Am I doing something wrong? #2
Sounds like your dealer overfilled them a mite. It wont hurt, just tough to check pressure.
   / Checking air in loaded tires......Am I doing something wrong? #3
Try giving the valve stem a shot of air to clear the fluid out of it before putting on the gauge.
   / Checking air in loaded tires......Am I doing something wrong? #4
Poke the valve with the tip of your little finger to let out some fluid. It should blow air through very quickly. Then stick the gauge on.
   / Checking air in loaded tires......Am I doing something wrong? #5
Also make sure you are not parked on a slope, side to side. You need to be level.. I always take the air chuck and shoot a little shot of air in first then then put the gauge on.
Great tips guys, I give them a try when I get on the tractor again. Possibly tomorrow.
   / Checking air in loaded tires......Am I doing something wrong? #7
You could still be overfull of course, but I mentioned the tilt angle in case that could have been an issue.
   / Checking air in loaded tires......Am I doing something wrong? #8
Assuming they're not chloride filled milton makes a gauge for filled tires just make sure to rinse it out when done. My tires are filled about 1-2" above the top of the rim
   / Checking air in loaded tires......Am I doing something wrong? #9
I just use a cheap air chuck with gauge from Harbor Freight. About $6. Give it a shot of air then read the gauge (with only air coming back at it). Or just use a cheap gauge, capable of showing very low pressure, and replace it occasionally. Either should be verified occasionally by comparison to a quality gauge.
I believe they are filled w/ chloride. I still haven't had a chance to re-check them........
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
2021 Caterpillar XQ125 125kVA Towable Diesel Generator (A55973)
2021 Caterpillar...
