Checking air in loaded tires......Am I doing something wrong?
   / Checking air in loaded tires......Am I doing something wrong? #11
If the tires are completely full of fluid you should have noticed them being very stiff without the ability to absorb much of anything.
   / Checking air in loaded tires......Am I doing something wrong? #12
I believe they are filled w/ chloride. I still haven't had a chance to re-check them........
I checked mine yesterday, and they all were down a couple of pounds, I guess from the cold weather
   / Checking air in loaded tires......Am I doing something wrong? #13
What PSI do you use James?
   / Checking air in loaded tires......Am I doing something wrong? #14
   / Checking air in loaded tires......Am I doing something wrong? #15
Give the valve a little burp and then taste the liquid that comes out. IF it is chloride, then it will taste salty. If Rim Guard then it will be sweet.
   / Checking air in loaded tires......Am I doing something wrong? #16
Sweet thats funny, definetly not how I would describe how rim guard taste. I got sprayed with Rim guard in the face one time as it shot out the valve stem. It does look like molasses though very dark brown.
   / Checking air in loaded tires......Am I doing something wrong? #17
What's it taste like?
   / Checking air in loaded tires......Am I doing something wrong? #19
Even if you are getting fluid out of the stem, if you seat the gauge on the valve stem, you will still get an accurate pressure reading. You can always bleed off the fluid till air/liquid mix starts coming out and then reinsert the valve core. There is practically no way to completely fill a tire unless you put some kind of upturned tubing into the stem to allow any air above the core to be forced out AND who in their right mind would do something like that. Once you bleed the air out so you are getting water from the stem, one could pressure the tire up to 20 PSI with additional liquid and perhaps fill 1/3 of the air cavity with liquid before the pressure build up would force you to stop filling.
I fill my own with pure water from my hose (not to much danger of freezing here). I listen for the sound of the water to change indicating that the stem is under water, remove the hose, bleed off the water till it starts to sprit out mostly air and then install the valve. Then adjust the pressure with additional air as required. One could do the same way by pumping in a proper amount of pure anti-freeze first, then hooking up a hose to finish filling with water.
Perhaps a bit off topic: But, my calculation of cost is about equal for using anti-freeze at $10 per gallon and methanol/water mix and might be a bit cheaper for using rim-guard if you are looking at -40 protection. For this temp you need 50/50 mix so a tire that holds 100 gallons would be $500 in antifreeze. Somewhere I heard that rim guard could be had for $3.50 per gallon so that would make it much cheaper than antifreeze solution for max low temp. At higher freezing temps one would find a break even point in cost between the 3.
   / Checking air in loaded tires......Am I doing something wrong? #20
Depending on how many gallons of AF one wants to install in a dry tire one can locate valve stem at 6 o'clock with tire jacked up and with the aid of a funnel just pour AF in then rotate tire so valve stem is at 12 o'clock attach water hose to continue filling. BTDT many times
204158 (A57193)
204158 (A57193)
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
