Checking a block for a crack
   / Checking a block for a crack #1
Poorboy04
Rixeyville Virginia
new holland TC24D
image.jpgimage.jpg. Is there anyway I can check this block for cracks without removing the crank?
   / Checking a block for a crack #2
It was mentioned in your other thread. You have the engine out so take it to an engine or machine shop and have it magnafluxed. They will find cracks if there are any and not be too costly.
Can they magnaflux it with the crank still in the motor.
   / Checking a block for a crack #4
They can check any surface that is visible. I doubt there would be damage under the crank. Since the head has cracks the next thing to check would be the top and sides of the block and cylinder bores. They can rotate the crank to check the cylinder bores without removing the pistons.
   / Checking a block for a crack #5
Magnaflux will find it. You can go over the head surface with a 3m disk, then follow up with a hand held wire brush kinda at a diagonal. Cracks show up that way.
MISC TIRES (A54757)
MISC TIRES (A54757)
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
