Check Your Curtis Snowplows
   / Check Your Curtis Snowplows #1
Greenway1
Foster RI
Kubota M-5700
We have two Kubota RTV 900's with 4 way hydraulic Curtis snowplows. I came home from plowing for the city to find one of the plows my wife uses hanging off the front of the machine by just the chain, I took a look at it and found it cracked on both sides at the front of what I call the A frame, I figured she must have hit something pretty hard, until I looked at the other rtv Curtis plow and found it had a hair line crack on both sides, but had not yet completely broken. It appears to be a weak spot, it is hollow and made out of box steel all the way till this point where they cracked. I have added some pictures so you can check yours. I know the welds are far from perfect but it did the job to get us through the storm.
   / Check Your Curtis Snowplows #2
How old are you plows? That looks like a real weak spot. Thanks for the tip.
They were both purchased with the machines, 1 is 6 years old and the other is 4 years old. Both have been good plows especially after making them hydraulic, however they will be getting replaced in the spring with the Boss V Plow.
   / Check Your Curtis Snowplows #4
I had my "A" frame let go this winter as well. I had found cracks in the two weak spots about two years ago and had it spot welded but it only lasted a season and a half. My son-in-law had it welded again and it has held the rest of the season. Before having it welded - which I didn't think would work - I was panicking and ordered two new "A" frames. I really didn't want to buy two but I ended up with two anyway - one from Curtis and another from a Kawasaki dealer. They each cost about $350 each. If you're interested I'll sell one to you for $300.
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
Hose Reel (A55758)
Hose Reel (A55758)
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
