check those screens
   / check those screens #1
megaboz
Platinum Member
Fairmont, WV
'17 2032r (soon)
I just changed my hydro fluid in my 2520, 70 hours. Scary find. I spent hours getting the metal shards, chunks and splinters out of the filter and my hands. Wear gloves when you do it! Live and learn I suppose.
   / check those screens #2
I removed the magnets, and washed mine with Diesel fuel at 50 hours. Mine did not have a much as your appears to have, but washed up quickly.
   / check those screens #4
Thanks for the info, I hope my new 2520 is in by the end of the week. This wait is killing me.
Yours look clean compared to mine. My magnets were covered in shavings. As a matter of fact I had no ideas there was 4 magnets in the screen.
I had been having issues with my hydraulics, and it was due. Surely being 20 hours past first change didn't make it look that way. I know 4 hours of it was at idle.
   / check those screens #6
That is a lot of metal and the color is darker than it should be. Hope your warranty is good because something bad is going on there.:(
   / check those screens #7
What is the standard transmission oil change interval for the JD2520? My 4520 does not require it for 400 hours.
   / check those screens #8
According to my operator's manual:
After the firrst 50 hours
Change engne oil and filter.
Change transmission oil and filter.
Clean transmission suction screen.
After that it's every 200 hours.
I may have been 20 hours late but that is no excuse for the shrapnel I found.
200 hours is too long in my opinion for such a small amount of fluid.
Either way in 10 hours I will be flushing it out again.
   / check those screens #10
im with you on the 10 hour deal man that filter look bad glad you found that before it caused major problems.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55218)
LIKE NEW 2023...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
