Check those nuts!
/ Check those nuts! #1
arizona98tj
Bemidji, MN
MF 1529
A couple of days ago, I was grinding stumps with my Woodland Mills WG24 stump grinder. A couple of hours into the session, I heard a noise. I stopped the grinder and discovered that one of the large nuts that holds a tungsten carbide cutting tooth in place had came off although the tooth was still in the flywheel, albiet unsecured. I was quite surprised since the nuts look like a Nyloc design although it could be another brand.
The tooth's square shank fits into a matching pocket in the flywheel, about an 1/8" deep, keep it from rotating. The tooth had beaten the pocket somewhat while it was coming loose but I was able to clean it up and reseat the tooth and put a new nut on it from my spare parts box. When I first looked at the pocket, I wasn't sure I would be able to salvage it.
I checked the owner's manual and the torque specs for the nut is 160 ft. pounds. Since my metric socket set stopped at 22 mm, I used a 15/16" socket which fit perfectly. Once the new nut was tightened, I spent a few minutes to verify the other 33 nuts and found that several took a bit of torque before clicking on the 160# setting. A couple on the other edge took about a quarter turn before cinching up.
I purchased the stump grinder last fall and after a few hours of operation, I checked the nuts per the manual. The take away for me is to check these a couple of times during the summer grinding season. It's super cheap insurance to keep the grinder working properly.
Just wanted to share this with the folks here that might have a stump grinder....as a friendly reminder.
/ Check those nuts! #2
Good info :thumbsup: walk about while tractor etc. warming up good habit.
/ Check those nuts! #3
I've gone one step beyond frequent checks. Three years ago I put BLUE Lock Tite on all the wheel nuts and all the nuts/bolts on the FEL. This, for me, has solved the problem of these nuts/bolts working loose. I still do an annual check on all these.
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
2017 Hyundai Sonata Sedan (A64557)
2017 Hyundai...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2017 Ford Fusion Hybrid Sedan (A64557)
2017 Ford Fusion...
1995 NAVISTAR INTERNATIONAL 4700 S/A FUEL TRUCK (A65054)
1995 NAVISTAR...
