Check this out - animated engine assembly
/ Check this out - animated engine assembly #2
Spark plugs?????? Sorry, if it requires a spark plug, it is not a "real" engine.
:D Bob
/ Check this out - animated engine assembly #3
Deutz is one of the oldest diesel engine manufacturers on the planet.
/ Check this out - animated engine assembly #4
I especially liked the clip where the guys were doing 165 MPH gum-ball racing to Miami.
/ Check this out - animated engine assembly #5
Is that how an inline four would normally be sequenced? With two sets of two cylinders firing together?
Chuck
/ Check this out - animated engine assembly #6
Chuck if you look again I don't believe that any two cylinders fire at once. That way the engine runs smoother. It is true that 2 cylinders do reach TDC at the same time but one is exhausting wile the other is firing.
/ Check this out - animated engine assembly #7
A standard inline 4 cylinder 4 cycle has 1 and 4 coming to TDC together and 2 and 3 moveing together. The fireing order however would be 1,3,4,2.
2022 YANMAR VIO35-6A EXCAVATOR (A63276)
2022 YANMAR...
Ford N Series Tractor (A66285)
Ford N Series...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
48" Farm Jack (A64127)
Bull Horn Decoration (A64127)
Bull Horn...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
