Backhoe check hydraculic fluid
   / check hydraculic fluid #1
ekyfom
mt. sterling KY
96 new holland
I have a 96 555E that I recently purchased and blew out a line and don't see where to check the hydraulic fluid, can anyone help?
   / check hydraculic fluid #2
Doesn't it have a saddle tank reservoir? If so, look on the reservoir above the step for a sight-glass. When you see fluid in that glass, you are at the right level.
Yes it does have a saddle tank with a sight glass and the fluid is low the lid is just some kind of vent, do you know how to add fluid?
   / check hydraculic fluid #4
Check in the toolbox on the tractor (if you have one) and see if you can find a large wrench. It is thin/flat and about 6" long. It looks like a big "Y" shape. You slide that under the plastic grip and loosen the reservoir opening, then take it off completely with the knob. I know it's a goofy setup, but that's the way New Holland does it. If you don't have one, they are $27 from New Holland. I think you could make one with a little effort though. See Item #14 in the illustration below.
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
