Check B7800 trans fluid hot or cold
   / Check B7800 trans fluid hot or cold #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Somehow this never came up but do you check the trans fluid on a B7800 with the machine warmed up or cold?
When cold mine is low but warmed up is closer to the operating level.
Thanks.
   / Check B7800 trans fluid hot or cold #2
The hydraulic fluid level in my machine is about the same regardless of temperature. It is however effected by the position of the loader and the 3pt hitch. If either one is up the fluid level goes down. Also when you first pull the stick nothing registers and then when you put it back in a second later and look again it will (should) show fluid level.
Yes, that is exactly the situation.
I check it and low, check again and OK.
   / Check B7800 trans fluid hot or cold #4
Nature of the beast. Don't know why though.
2008 PETERBILT 335DAY CAB (A51222)
2008 PETERBILT...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
2017 BIG TEX 16 T/A UTILITY TRAILER (A50854)
2017 BIG TEX 16...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A50854)
2021 ALLIANCE...
