Cheap Lawn Striping Attachment
/ Cheap Lawn Striping Attachment #21
Hi Gene,
Can I play the dummy on this thread??? Will someone please explain to me why you need a stripping attachment, and what exactly does it do? Mark the lawn for a certain width? When I cut around the house with my Wheel Horse with the 42" deck, you can kind of see a stripe, does this attachment make it more pronounced ? And make the lawn have a better appearance?
Not trying to be smart, just trying to get a grip on this attachment /forums/images/graemlins/grin.gif
/ Cheap Lawn Striping Attachment #22
Hi Gene,
It makes the stripes very pronounced. You can see similar striping methods at some major league ballparks.
It is purely personal preference.
If this is my biggest problem right now things are going pretty good. /forums/images/graemlins/grin.gif
/ Cheap Lawn Striping Attachment #25
There are actually people who buy the Simplicity lawn mowers just for the striping effect from their deck rollers.
I kinda like to mow my lawn and not leave any sign that I've been there, but for the trimmed and even stand of grass. The less the better. But I'm wierd, I'll admit. /forums/images/graemlins/grin.gif
Some strip their lawn by using a drop fertilizer spreader /forums/images/graemlins/tongue.gif Makes for some definite stripes.
/ Cheap Lawn Striping Attachment #26
Nasty135,
Thanks for the kind words.
It was a little more than I had wanted to spend. /forums/images/graemlins/grin.gif
Nasty135,
/ Cheap Lawn Striping Attachment #29
Gene,
That is an interesting concept...striping before cutting...I will have to read the thread again to make sure I did not miss something, like striping AFTER cutting... /forums/images/graemlins/blush.gif
I just wonder if it would not be better to have the striping rollers behind the tractor. I would think it might be a pain to some degree, but one could hook a striping roller set up to his 3PH, and raise the mower deck when changing direction, maybe...
Your setup sure does the job better than mine does though... /forums/images/graemlins/blush.gif
/ Cheap Lawn Striping Attachment #30
Gene,
/ Cheap Lawn Striping Attachment #31
Scott do you use a RFM, or a MMM and do you mow then stripe? An ideal solution naturally would be to stripe while mowing.
Nice project and it looks heavy duty.
/ Cheap Lawn Striping Attachment #32
Henro,
I should have taken a wide angle shot. The roller is on the back end. It is a zero turn mower, not a tractor. /forums/images/graemlins/blush.gif
So as I mow it follows the mower from behind.
Henro,
/ Cheap Lawn Striping Attachment #35
</font><font color="blue" class="small">( For the framework I used some spare black pipe and bent it with my cheap hydraulic bender. )</font>
Gene, can you tell me (or show me) what type of cheap hydraulic bender you have? thank you.
/ Cheap Lawn Striping Attachment #36
Stanley,
I bought one at Harbor Freight on sale for $69.99 Right now they list it in their "online" catalog for $74.99
I will attach a picture.
Here are the specs:
12 TON HYDRAULIC PIPE BENDER
Heavy Duty Steel Frame
Bends 6 different diameter pipes from 1/2" to 2". Bending bars can be adjusted to distances of 8-1/2", 11-1/4", 12", 16-3/4", 19-1/2" and 22-1/4". 2" diameter 12 ton jack. Jack capacities: 13-1/4" minimum; 22-3/4" maximum; 9-1/2" stroke. Precision cast dies.
Round or square solid rod capacity: 2''
Handle: 17-5/8"
Overall size: 24" wide, 6-1/2" deep and 21-1/2" high.
Shipping weight: 117 lbs.
Stanley,
Here are the specs:
Handle: 17-5/8"
/ Cheap Lawn Striping Attachment #39
Mike, I use a MMM and stripe while I mow. It works really well and I think my yard is getting smoother, LOL.
Scott
/ Cheap Lawn Striping Attachment #40
Scott
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Metal Donkey Statue (A64127)
Metal Donkey...
Frontier Grapple (A64127)
Frontier Grapple...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2015 Case TR320 (A64126)
2015 Case TR320...
