Cheap lake home? May or May not happen. (It is a go!)
   / Cheap lake home? May or May not happen. (It is a go!)
New cutting teeth were a big improvement in the hard soil. I had also watered the holes to soften them.
Remaining side is just as level. We had to flip the 6 x 6 x 24 to remove a bad bow and get a good side to work with.
I have more bags of concrete to add to finish up the base.
Oldest son was a big help on his day off.
   / Cheap lake home? May or May not happen. (It is a go!) #302
Thanks for the updates, glad to see you’re moving forward with your projects. Will you be installing the carport or having a company erect it? I’ve considered adding a carport on my property, your 6x6 base may be the way I eventually do mine.
Mike
I will have them install it. Seems like all of the companies include free freight and installation. 25’ panels can be a lot to handle if there is any wind. I have installed 25’ panels on my lean to we built and it was hard to not bend them.
I don’t know if I pointed out that I used Galvanized lag bolts, not Zinc in the treated wood.
Dropped another 16 tons of gravel for the carport base. I let it sit with the clay I brought in for a few months. The carport should be there in January. It will be 18x26x8. This gives me a center height of 11’3”.
Original 4 x 6 posts were attached to a sunsail. When we had a 40-60 mph
Storm they moved. I had them in about 2’ with concrete but the ground was softer than I thought. New 6 x 6 posts are over 3’ with more concrete. They should never move!
When I showed my 3 sons what 64 year old dad had done, the reply was you had a tractor. I explained I had to stand them up straight to hook up the sling and they were heavy treated and wet. I am not sure they always appreciate my projects. 😀 One day they will. My 90 year old dad does.
18 x 25 carport installed. They built it like they were fine furniture craftsmen. Maybe a slight exaggeration. They did take great pains to keep everything square and level. Super organized and in 2.5 hours they were complete.
I used 1/2 x 6.5 galvanized screws to go into the treated 6 x 6 base.
I am trying to figure out how to get a pontoon in there as well. Both pictures have the trailer in the same position. I may swing the cargo trailer perpendicular.
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
