Cheap lake home? May or May not happen. (It is a go!)
   / Cheap lake home? May or May not happen. (It is a go!)
New cutting teeth were a big improvement in the hard soil. I had also watered the holes to soften them.
Remaining side is just as level. We had to flip the 6 x 6 x 24 to remove a bad bow and get a good side to work with.
I have more bags of concrete to add to finish up the base.
Oldest son was a big help on his day off.
   / Cheap lake home? May or May not happen. (It is a go!) #302
Thanks for the updates, glad to see you’re moving forward with your projects. Will you be installing the carport or having a company erect it? I’ve considered adding a carport on my property, your 6x6 base may be the way I eventually do mine.
Mike
I will have them install it. Seems like all of the companies include free freight and installation. 25’ panels can be a lot to handle if there is any wind. I have installed 25’ panels on my lean to we built and it was hard to not bend them.
I don’t know if I pointed out that I used Galvanized lag bolts, not Zinc in the treated wood.
Dropped another 16 tons of gravel for the carport base. I let it sit with the clay I brought in for a few months. The carport should be there in January. It will be 18x26x8. This gives me a center height of 11’3”.
Original 4 x 6 posts were attached to a sunsail. When we had a 40-60 mph
Storm they moved. I had them in about 2’ with concrete but the ground was softer than I thought. New 6 x 6 posts are over 3’ with more concrete. They should never move!
When I showed my 3 sons what 64 year old dad had done, the reply was you had a tractor. I explained I had to stand them up straight to hook up the sling and they were heavy treated and wet. I am not sure they always appreciate my projects. 😀 One day they will. My 90 year old dad does.
18 x 25 carport installed. They built it like they were fine furniture craftsmen. Maybe a slight exaggeration. They did take great pains to keep everything square and level. Super organized and in 2.5 hours they were complete.
I used 1/2 x 6.5 galvanized screws to go into the treated 6 x 6 base.
I am trying to figure out how to get a pontoon in there as well. Both pictures have the trailer in the same position. I may swing the cargo trailer perpendicular.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2015 F-550 Bucket Truck. (A53472)
2015 F-550 Bucket...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
Ex Mark Zero Turn (A51573)
Ex Mark Zero Turn...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
