Cheap Key Safe
   / Cheap Key Safe #11
in the bedroom would be a red flag, wouldn't it
Depends on the electrical equipment you have in the bedroom:eek::eek::rolleyes:
   / Cheap Key Safe #12
With the right stickers on it I am not sure anyone would ever look there -- including the electrical inspector:p
Hmmmm....now I know what to do with the old fuse box with the knob and tube wiring!!
   / Cheap Key Safe #15
LMAO you guys sure know how to crack up a guy reading at work.But seriosly the elec box sounds great .But do as I do,sign reads "THIS HOUSE IS PROTECTED BY A SHOTGUN 3 NIGHTS A WEEK",you guess which "3".:D
   / Cheap Key Safe #16
When I was production engineer in tool factory - long time ago - I build a small safe myself. Since it was in Prague, all houses are brick or concrete and all you needed was the front plate and a hole in the wall.
Anyway, I found some scrap metal - it was CSN19552 tool steel for aluminum molds, I think US equivalent would H13 - one inch thick plate. I squared it on a mill and drilled as big hole as possible in the middle and on big lathe turned corresponding piece. For the lock I used a door lock insert with some modifications. There were no hinges, you had to unlock the round piece and take it all out. The whole thing was 20 pounds or more and to take the door out you needed both hands. But it was free - and the steel was an overkill:)
Reminds me of friends dad. He worked in a Airplane factory and in the heap pile found a fan from turboprop engine. Next thing you know, it was a cutting blade on his push mower:D
2016 Ford F-350XL (A57148)
2016 Ford F-350XL...
Club Car Electric Utility Cart (A55853)
Club Car Electric...
AG-FAB PULL TYPE SWEEPER (A58374)
AG-FAB PULL TYPE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
