Cheap Fence Posts?
/ Cheap Fence Posts? #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Thru 5/9 HD selling 4x4 8ft treated posts @ $4.97 ea. Any reason not to use in 4 rail wood fence project? Plan on setting in concrete w buid-up @ ground level. Sandy soil. Fence for looks mostly.
/ Cheap Fence Posts? #2
Should work fine. Its what I used for my fence posts and there still doing great after 10+ years with the exception of the weedeater damage along the base!
/ Cheap Fence Posts? #3
I used 4x6 's on this entry -- 4x4's I've used in the past twisted on me.... this has been up since Thanksgiving 05 .... no twist yet....plenty of shrinkage on the boards though... where I butted them up on the post there is a 1/2 inch gap on a couple of them now. I may have to reset the screws holding it on.
/ Cheap Fence Posts? #4
I have 4x4s except for where the gate hinges are attached (4x6 there) and they hold up great. other posts talke about putting pressure treated into concrete. I used stone for mine. But then again i dont have a sandy soil. Its rock with little bits of dirt inbetween.
Forgeblast
/ Cheap Fence Posts? #5
I just saw Lowes selling treated landscape timbers here for $1.97. I had them throw an enire pallet on my trailer for this price. Work better than any cedar posts I had used in the past. These are 3x5 8' posts with 2`flat sides.
Put them in the ground wide sides out. I have some that have been in the ground for 20+ years. None have ever rotted. Use them for brace posts, too. Yes they are $4.97 at HD.
/ Cheap Fence Posts? #6
That may be the case for you, but my experiance has been that landscape timbers may be very poorly treated and some rot out very quickly while others last much longer.
/ Cheap Fence Posts? #7
I'm in that boat as well. I've used landscape timbers for fencing, and one lot from one place willlast like a PT post.. and then the next lot from another store will rot out like I burried #2 white wood spruce. I think I all comes down to how well it got treated.
Soundguy
/ Cheap Fence Posts? #8
I used 4x4 for the post with a 1/2 bag of cement and 6x6 for the gate. The cross boards were 6 by 8 by 4/5. The costs were $4.50 per post, $4 per cross board so it was a little expensive but since it was beside the house I thought it should match the deck. I plan on doing a property board fence but I want to do this much cheaper as it will be out of sight. What have you all come up with for cheap posts?
/ Cheap Fence Posts? #9
Best fence posts I ever had were utility poles cut to length and sawed down the middle... last forever!
mark
/ Cheap Fence Posts? #10
You better look close at the label.
I am rather furious at Lowes right now. I too bought a bunch of them for $1.97 from the Lowes in Winchester, VA -- thinking they were pressure treated, and suitable for landscaping. They looked like pressure treated wood! They are labeled "8' LANDSCAPE TIMBER", barcode 00738 50600.
I loaded my pickup with them last weekend - with no help from anybody at Lowes -- just a comment from an employee that other's needed to get past where I was attempting to load my truck!!
I got them home, and transferred them from my truck to my trailer, which I dragged to my project with my tractor. After I set about the 6th one, the barcode label caught my eye:
ABOVE GROUND USE ONLY
NO RETENTION GUARANTEED
SURFACE TREATED FOR COSMETIC PURPOSES
They have all the customary "Important Information" about using the right kind of hardware, using a mask and goggles, not using in direct contact with aluminum, and on and on . . . .
I guess I'm going to return them. Why would anybody sell a landscape timber that is for "above ground use only"??? It sure seems like misleading, if not downright dishonest advertising.
/ Cheap Fence Posts? #11
I use bad language everytime there is strong wind blowing in our are. The PO built 10 feet tall fence from boards and all it supports is landscaping lumber. The fence is 20 years old and wind always takes a part of it and tosses it backwards. I am slowly replacing fallen pieces with 4x6 posts.
/ Cheap Fence Posts? #12
A drive through the country here on the NW coast after a 90 mph winter storm will tell you why not to use a 4X4 PT as a post in a rail fence. I work in the building material industry, and history has shown that when a piece of wood has been kiln dried, then treated, it loses considerable shear strength. It becomes brittle enough to often break just by dropping it.:eek: My opinion is to use a 4X6 minimum for a post. 6X6 is even better, unless you like diggin' post holes in the winter better than I do. Ideal corner and gate posts are used railroad ties. They are about the only posts that stay up on my farm when the resident herd of about 50 elk get spooked.
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
Star (A64557)
Star (A64557)
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
