Dirt Moving Cheap Cable Trencher?
/ Cheap Cable Trencher? #1
WeldGuy
Kubota BX2200
Has anyone made a cheap cable trencher attachment for installing wire about six inches down? We'll be installing some invisible fencing for the pup.
/ Cheap Cable Trencher? #2
Yes I did... Buried coax with it. Worked very good.
basically I took two 8" x 6" plates of steel (1/4 plate), welded the 8" edges together to form a V with the wide end of the V about 4" apart, then welded bracing in to the open end of the V.
Then on what would be the top of the V closer to the point I welded two 3/4" nuts per side. (I did this with them on 3/4" all thread so the threads would line up).
I then took a piece of scrap 3" x 3" 1/4" angle and drilled two holes in it.
To use it you basically slide it over a tooth on the back hoe and tighten the nuts clamping the V under the bucket and the angle in the bucket.
I straddled the wire with the tractor and dragged a ditch about 100', while the wife simply put the wire in the ditch (which ended up about 5 or 6" deep) and pushed the dirt back covering it.
/ Cheap Cable Trencher? #4
Are you driving the tractor forward and dragging the backhoe? Or are you pulling forward and manipulating the backhoe every 3-4 feet? Yeah, a picture would be great.
Deano
/ Cheap Cable Trencher? #5
I used a subsoiler to bury some thin walled PVC hose - don't see that it would be functionally different from doing the same with cable. Warning - the following picture includes duct tape:
/ Cheap Cable Trencher? #6
I have a single bottom plow and removed the wheel which is to set the depth. I dropped it and drove forward and it cut the most perfect 6"x6" trench I've about every seen with the removed dirt piled on one side. I did it for drainage and it did it so clean and easy that I did about 5 times as much as I needed. So, if you have a single bottom plow or can borrow one, it's something to consider. Just have to come back along and cover your ditch with the dirt piled on the one side.
/ Cheap Cable Trencher? #7
I am in NH wedge is in CT I will have wife take a picture and send it. I will post it later.
I used the backhoe (I had a case 680 at the time) to pull about 12 feet at a time. I didn't have to use the stabilizers the park brake was enough to hold the tractor.
By using the boom, dipper and bucket I could stretch way out and pull the dipper towards me while lifting the boom and rolling the bucket.
It did a really good job. the grass was back to normal within a couple weeks.
/ Cheap Cable Trencher? #9
For a dog fence wire we just use a edger if you don't have one a local rental store should be $50 or less for the day. Hard to build something for less.
/ Cheap Cable Trencher? #10
Mine looks ugly compared to the above or the ones in the link
2018 Yamaha VX1050B-TA Waverunner Jet Ski with2010 trailer (A59231)
2018 Yamaha...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
John Deere 5045E for sale
John Deere 5045E...
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
