Chatter Fix for TC-45D
   / Chatter Fix for TC-45D #11
JT, I looked at mine a little closer last night and it is a little looser than I previously recall. Still though, no rattle. I also noticed that there is not much room for the entire cover to move front-to-rear. Maybe you could loosen the clamp and slide the rear part more to the rear and the front part more to the front and thereby tighten the whole setup up. I think mine probably had only about a 1/8" free-play, when I would try to slide it front-to-back. Good Luck!
Boy do I feel like a dummy! The cover (shroud) does have an integrated clamp nearest the transmission. Loosen the 4 bolts and extend it for a tighter fit. Previously, I examined this thing and I even fooled with it. The only excuse I can offer is that when the clamp is tight the seam is nearly invisible. Things are now quite again. This web site is great..... thanks all!
JT
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2005 UD Truck UD1300 Landscape Dump Truck (A56858)
2005 UD Truck...
Honda Pioneer 700 Utility Cart (A56857)
Honda Pioneer 700...
Hose Reel (A55787)
Hose Reel (A55787)
2008 Pierce Enforcer 61ft. Quint Ladder Fire Truck (A56858)
2008 Pierce...
Toro Dingo Mini...
