charging system
/ charging system #1
michael_johnson
2006 fonton 254
i have a 2006 fonton 254 tractor the altenater is charging 18 volts so is it the altenater or voltage regulator
/ charging system #2
The alternator puts out a higher than necessary voltage. The voltage regulator should drop it to around 13.5 to 14.5 or fifteen volts. However if the wires are not connected to the battery they have no reference point. How high does the battery charge? If charges the battery to eighteen volts you probably have a regulator problem. If it charges the battery to fourteen volts or so, after the engine is turned off the battery will drop down to the normal 12.6 volts.
/ charging system #3
If it is wired right, and the alternator is putting out DC voltage, and the battery is good, then the problem is most likely in the voltage regulator.
Alternators by themselves are made to put out 14 volts at a fast idle and it is normal for them to put out more voltage at higher RPM. The Voltage Regulator's job is to reduces that to a voltage that charges the battery properly. For a 12 volt battery the charging voltage is around 14 volts.... just as RoadWorthy said.
/ charging system #5
This looks like it's going to be a fun read. :ROFLMAO:
Perhaps your volt meter is incorrect or it's on the wrong source setting.
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
60 Traffic Cones (A65579)
60 Traffic Cones...
2016 VOLVO SD115B SMOOTH DRUM ROLLER (A65053)
2016 VOLVO SD115B...
