charging system doesn't work
/ charging system doesn't work #1
pontiac58
vineland nj
terramite T5C, bolens g152
I have a 1995 or so T5C with a honda. Just got done rebuilding some cylinders, changing a few lines, making all the pins take grease, and rebuilding the front axle from hub to hub. Previous owner did no/zero maintenance
Anyway, my honda doesn't charge the battery. The wiring harness is a wreck, i would rewire it, but time is limited right now and i just need to get it charging for the winter. Does someone have a schematic for this unit or what wire colors do what?
I read around the web trying to figure out how the hondas charge, but couldn't really find what i wanted, but another question came up. Does terramite use a 20 amp or 3 amp charging system?
Thanks Jim
/ charging system doesn't work #2
:welcome:
/ charging system doesn't work #3
Welcome Pontiac58 to the forum. I am not sure about the Honda. I would call the Terramite service department. I have had good luck with Eric. He is very knowledgable about these Terramites and suspect he will be able to give you a quick answer.
I understand having a Terramite whose previous owner did NO maintenance.....I have spent hours doing the same thing.....I still have a few pins not taking grease.
Good luck getting it charging!
/ charging system doesn't work #4
Google "terramite t5c parts" and there is everything,wiring diagram and all.Look up what model honda you have-GX620? and it probably has 17 or 20 amp.FREE parts manual-color coded wires and all.
Thanks for the tip on the wiring diagram. I had the parts catalog printed out, just never went past the parts section. I found at least part of the problem. The diagram calls for a 5 terminal switch and mine is a four terminal and the brown wire isn't hooked to anything. It got dark out before i could finish but what does the brown wire do???
/ charging system doesn't work #6
It looks like the brown wire is the Kill wire-to shut off engine.It would go to ground through the switch.Be carefull that you don't send positive through that wire-might blow the ignition coil(s) Been there,done that! It is also tied to the low oil kill.
You probably are going to need a new voltage reg. If you try to charge a dead battery,they burn out.If your battery is low enough that you have to jump it-charge it up,don't jump it.
I see it has a fuel shut-off solenoid on the carb,and that is probably what shuts it down now.
Now that you said that, it does take its time shutting off. Hopefully it isn't too cold out this weekend and i will be able to get outside with it for a few hours.
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2023 Giant G2500HD Mini Articulated Wheel Loader (A66734)
2023 Giant G2500HD...
DEERE 544K Quick Attach Coupler (A68134)
DEERE 544K Quick...
