Charging problem
/ Charging problem #1
timbertree
Bentleyville PA
John deere 318
I have a John Deere 318 garden tractor, that has a charging problem when mowing for about 15 min.
For some reason, the battery warning light comes on "about 15 min after I start mowing". If I turn the mower switch off, the battery warning light turns off.
My question is, where do I start? I know this battery is fully charged. So it's not the battery, and the PTO clutch is properly adjusted. I guess this leaves the rectifier? Does any body out there that messes with this type of stuff know what it is that's causing this problem? Or most likely know what the problem is.
Thank you
/ Charging problem #2
Don't know the answer but my Cub Cadet light stays ON for 15 mins after mower clutch engaged, then finally goes out. So I'm interested in the answer!
Jim
/ Charging problem #3
check charging voltage
/ Charging problem
I think it does, but not sure. I'll have to look into this again. But not today. thanks.
/ Charging problem
Murph, thanks for the information and help. For some reason it's working now. All I did was move the wires around, and pulled all three connectors on the rectifier, and cleaned all the spades up. Oh, by the way, the battery did drop down and level out like you said it would after running it for an hour.
/ Charging problem #8
What engine Model and # is in it? If its a Kohler, some have a dual system where the Electric clutch for the deck is run off
of 1 and the charging of the battery is a separate system.
/ Charging problem #9
Make sure your connections are clean and tight and your good to go.
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
Wood Fence Post (A62613)
Wood Fence Post...
2011 Western Star Tractor (A62679)
2011 Western Star...
