Charging problem on my John Deere 4100
   / Charging problem on my John Deere 4100 #21
How about that, still working great!!! Thought I would pass it on since charging issues can be one of the most frustrating problems to fix. I was looking at my threads and I never mentioned I believe it is some sort of safety relay that's tied with the transmission. This would make sense because if it was malfunctioning it would always pull a draw and/or cancel a draw. Hope this helps others in the future. If anything, another option to consider.
I have a 4100 also. I had similar charging issue. I fooled around with the electrical for months. As I recall there was a relay or some connectors that when I unplugged/re-plugged it magically cleared it up. Yes, I recall a relay-ish part -- that I removed and installed a few times. It's been a few years; has worked find since.
   / Charging problem on my John Deere 4100 #22
My question is this. Will the 4100 work w/o the relay. John Deere ( James River Equipment ) now list the part as $150 plus. Ebay has one, but does not list as new or used for less than $40. and This drain is killing me during the days work..
I have no idea if it can work without it, I didn't try. I would think not since it's partially a safety relay. The money was well worth it for all the frustration it has saved me. Nothing sucks more than a drained tractor when you're right in the middle of trying to get things done. Good luck
   / Charging problem on my John Deere 4100 #24
I think the second from the front is the voltage rectifier/regulator discharge light relay. I have a 4100 HST and I have the light staying on. I just replaced the voltage rectifier/regulator module(original burned out due to an accessory wire that shorted and took out rectifiers/regulator module) and now have 14.8 volts at run speed. My problem is that the voltage stays in charge mode all the time now.
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
White Metal Roof Panels (A55758)
White Metal Roof...
2012 Chevrolet Traverse SUV (A55853)
2012 Chevrolet...
2019 Freightliner Derrick Digger Truck (A55973)
2019 Freightliner...
Eagle Weathervane (A55853)
Eagle Weathervane...
23013 (A55787)
23013 (A55787)
