Charging problem on my John Deere 4100
/ Charging problem on my John Deere 4100 #1
Towmater
John Deere 4100
Hello! I've had a little problem with having a dead battery. I hooked up a flamming river disconnect switch to see if that would fix it and it seems like it could be the alternator. After charging the battery on a slow charge overnight the charge was at 12.68 volts. I parked it outside during the day and let it run for 15 min with the lights on and the volts dropped to 12.02 while running. I turned the lights off, let it run some more and was slowly climbing to 12.28v and then 12.30 volts. I checked it late last night and the volts after sitting was 12.5v. Note, this is a new battery too but I thought the problem was the battery at first. Does this sound like a bad alternator to anyone? Shouldn't the volts when running be more like 13.0 volts??? Need help... I'm a rookie at this stuff but I think I am on the right track.
/ Charging problem on my John Deere 4100 #2
Yes, I do think you are on the right track. Charging at half throttle should give you close to 14V with lights out.
/ Charging problem on my John Deere 4100 #3
Check for proper belt tension. As stated 14v running, not at idle. Battery will (should) maintain 12.5 +- after setting. If stored in barn( any place) mice love the insulation on wires. Have found shorts.
Thanks for the advice! I think the next step is to put it at half throttle when running and double check it. I do not believe I was at half throttle when I checked it. Thank you.
Ok guys, I changed the voltage regulator per advised by dealer and no good. I changed the alternator and went from running volts with lights on from 11.97 volts to 12.23 running volts with the new alternator. Without the lights on it runs at 12.5 volts. What do you think? I'm thinking I should be ok. Hopefully so because the snow is coming. When the tractor is shut off it stays at 12.68volts which is the same as my suv. I think I have it fixed. No where near 13.90 volts though like some stated.
/ Charging problem on my John Deere 4100 #6
OK, I have the same problem as Towmater. I keep a trickle charge on to keep the battery voltage up. I have had the battery load checked and it is fine. I have checked the termanals and they are clean of corrosion. With a fully charged battery of 12.9V I started the tractor. At idle 1000 rpm I have 11.95v. At 2500 rpm I have 12.21v. After 5 minutes of run time, shutting down the engine and the battery voltage is 12.7v. Are there any adjustments to tweak the voltage regulator or alternator. On my cars and trucks I just check ther battery voltage with the engine running to check out the alternator. I would have thought that Towmaster would have had 14v with a new alternator. Are there any checks that I am missing? Is there a good place to get an alternator? I can live with the trickle charger that is directly wired to the battery and easy to connect/disconnect but the wife doesn't like getting stranded in the field when she shuts down the tractor after a long idle.
Well absaroke, I'm still having the issue. Bottom line is mine is not charging enough while running. I can have a full charge and it still will drain with the new alternator. After a heavy day of use and running and starting it sometimes will die at the end of the day. I've recharged the battery and the at times will sit for three weeks with the battery disconnect switch disconnected and will fire right up. So I've feel it just is not charging enough while running per my other threads to this. I've decided I'm going to let a dealer look at it in about a week so I'll let you know, I'm tired of screwing with it. I just feel the volts should be much higher when running. Who knows, maybe the dealer sold me the wrong alternator because they were back and forth on two different ones.
/ Charging problem on my John Deere 4100 #8
Most modern alternators have a built in regulator, So if the belt is tensioned correctly and all connections are good, then the alternator/regulator is not working correctly, and yes the charging voltage should be about 13.6 to 14.1
Your battery is running the tractor the alternator is pretty much not even there. Take it and have it tested or get a new one. If you by chance have and external regulator, then start looking there.
James K0UA
/ Charging problem on my John Deere 4100 #9
Towmater and James
James - I agree what the voltage should be and that mine is not putting out the correct voltage.
Towmater - I'm anxious to hear the results from the dealer. I was quoted about $350 for an alternator. I will just keep the trickle charger hooked up if that is the real price.
Update. I dropped off my JD 4100 at the dealer today, printed off my thread from here and gave it to them. He confirmed when running the voltage should be right around 13.5volts. I told him I feel there is a draw somewhere considering when running it is draining and also when shut off it will drain the batteries after about three weeks. BUT- then again that might of been after running it for 1/2 a day and then parking it. I feel it is something charging related. Could very well be the new alternator is bad too. We will see!
/ Charging problem on my John Deere 4100 #11
Towmater - do you have a part number for the alternator?
/ Charging problem on my John Deere 4100 #12
Towmater
Do you have an update? Did the dealer find the problem? Do you have a part number for the alternator?
Well, my tractor has been there for two weeks and no calls. I just called them and they said the have a relay on order for it and that is all she could tell me. How about that! I wasted all my **** money over a relay! Another lesson learned it is better to just take it to the dealer first! I'll give you the info when I go and pick it up. The alternator # though is SE501843. Was $220 dollars when I bought it. If I were you I would wait until I find out what the relay is and where t is located. My loss, your gain! Good for you!
/ Charging problem on my John Deere 4100 #14
Thanks for the update. I couldn't go 2 weeks without the tractor. I have 4 draft horses and they poop often and alot.
Three weeks to the day I picked up my tractor from the dealer. They found a relay bad # M808087. They told me it is under the plastic cover by the steering column on the right side, second one back from the front. They found 28volts coming out of the alternator, 28volts going into the voltage regulator but none coming out. Thy tried a new voltage regulator (even though I put a new one on) and same thing. That's when they found the relay bad. I now have 13.36 volts half throttle and 13.49 at full throttle. Even when running all the lights I never go below 13.04 volts. The bad news... they are not sure if that will fix the draining issue! I have a FLAMMING river disconnect switch so I'm not to worried about that since it will now charge while running! I'll try to post another update once I monitor it for a few weeks. I'm hoping all my troubles are behind me now and hope to help others with my findings. Man, it cost me $350! The stupid relay was $90.48. Good luck all!
/ Charging problem on my John Deere 4100 #16
Thanks for the input. The John Deere Illustrated Parts Manual lists the M808087 Relay as the PTO Indicator Lamp (Safety Relay) in the location that you describe. The terminology of the relay is a little confusing as to why it would control voltage from the alternator to the battery. I will try and trouble shoot the problem tomorrow. I need to double check and see if I get any output from the alternator.
Update, my tractor has been good ever since. So far s good! I talked it over with some buddies of mine and fell that the key word of the relay is "safety". Probably something tied in with the tranny for safety. I'm just glad it is finally charging.
Well I thought I would post an update. The tractor for sure is fixed. It has been good ever since the dealer replaced the relay! Whoohoo! I still use a disconnect switch but the trouble of draining the battery while running the truck is fixed. Any tractor can drain a battery over time if it sits long enough so that's why I use the disconnect still. Good luck all and I hope this helps somebody else in the future :0)
/ Charging problem on my John Deere 4100 #19
Tx for the update! :thumbsup:
How about that, still working great!!! Thought I would pass it on since charging issues can be one of the most frustrating problems to fix. I was looking at my threads and I never mentioned I believe it is some sort of safety relay that's tied with the transmission. This would make sense because if it was malfunctioning it would always pull a draw and/or cancel a draw. Hope this helps others in the future. If anything, another option to consider.
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
2006 FORD E350 CARGO VAN (A66091)
2006 FORD E350...
CAT 740 Engine (A68134)
CAT 740 Engine...
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
2013 Ford Fusion Sedan (A66738)
2013 Ford Fusion...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
