CHARGING PROBLEM FORD 5610
/ CHARGING PROBLEM FORD 5610 #2
what kind of problem are you having 1985 model should have a motorola alternator number 8al2055f 12 volt 32amp
Ford 5610 1985, Motorola alternator and voltage regulator. These have been replaced. I do not get power feed to the regulator.
/ CHARGING PROBLEM FORD 5610 #5
G'day IIRC you should have a charge light on the dash, does this light up when you turn the ign on?? If not then check globe as power need to travel through the globe to excite the alternator.
Jon
Jon
I was trying to find a plan to follow the wiring of the charging module. Even the book I bought and downloaded ( published by ford at the time) was not clear to me. To many models of tractor in the same book. 2500+ pages.
I finally ran a new wire between the alternator and the starter and everything works.
Thank you
213135 (A64276)
213135 (A64276)
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
KUBOTA Z121S KOMMANDER ZERO TRUN MOWER (A65054)
KUBOTA Z121S...
1024 (A63111)
1024 (A63111)
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
