Charging A New Battery?
   / Charging A New Battery? #11
Mike I think now is the time to take it back to the dealer and have it tested. Once in a while you get a bad one. As long as they make it right it's ok.
   / Charging A New Battery? #12
Junkman,
Yuasa & Battery Tender are just two good mfg's of battery float/maintaining chargers. They sense the voltage of the battery and charge it when low. They do a great job in keeping the battery healhty...They really don t cost that much either...
Duc
   / Charging A New Battery? #13
Mike, you didn't say how many volts are showing on the battery; However the "yellow top" being a deep cycle battery, it should take a 10 amp charge with no problem. You need 12.6 volts for a fully charged battery.
<font color="blue"> You need 12.6 volts for a fully charged battery. </font>
This is a real mystery...I just checked the voltage with my digital VOM and it's 12.97.
I put it on the charger, at the 10 amp setting, and the needle on the charger is in the 'Charging' area.
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Charging A New Battery? #15
Very strange....Are you sure the 12.97v wasn't with the battery hooked to the charger? What voltage does the working battery show on that meter?
<font color="blue">Are you sure the 12.97v wasn't with the battery hooked to the charger? </font>
Yep. I had the Optima on the charger for the last hour or so and it reads (charger disconnected) 14.14.
<font color="blue">What voltage does the working battery show on that meter? </font>
12.59
   / Charging A New Battery? #17
That's no mystery here it's the sign of a shorted cell.. It's holding a static charge indicating 12.97+ but if you leave it or apply a load it'll drop and the shorted cell when you hook up it up to charger is making the charger force juice to the battery thus overcharging the other plates further damaging the battery alot of times it'll ping or spike if you have a needle guage. If it was mine i'd be getting rid of it..
The real test is putting it on and applying a load and viewing the volt meter. probaly 10v or more would pass..
<font color="blue">That's no mystery here </font>
It might not be a mystery to you, but it was/is to me. /forums/images/graemlins/grin.gif
I have sent another email to tna-sports.com (where I bought it) indicating there's probably a shorted cell. I dont expect them to respond over the weekend. We'll see tomorrow.
   / Charging A New Battery? #19
for what that one battery cost, you could buy 3 Wally World batteries and still have enough left over for a cup of coffee and a donut!!!!!
   / Charging A New Battery? #20
Providing they don't leak and leave a massive cancer mess like so many of the stock JD's were having. I think this has caused many folks to consider a non fluid type battery. The area where the battery is, is no place to have acid as the radiator, oil cooler etc. will be destroyed in little time. I've not experienced the problem on my tactor, but my neighbors JD 790 has destroyed two cable ends besides the original one and eaten the holddown area up pretty good. He replaced it with another lead acid that hopefully will arrest that problem.
I use a "Battery Tender" brand charger permananetly on my powered gate battery. It's a very good way to keep a battery at the optimium level and never overcharge. It can also provide enough current to quickly charge a low battery.
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2010 Volvo XC90 (A56859)
2010 Volvo XC90...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
