charge light staying on ???
/ charge light staying on ??? #1
harry trattner
Hi everyone I have a 1610d yanmar w/ 670 hours I havbe had it for 1month ,I did about 3 days of FEL work and some box scraper stuff without a problem,but after I washed the tractor (was careful not to get water in motor area ,the next day the charge light stays on after the motor is started so I read the manuel and increased the idel speed and the light will dim alittle not much, the belt is new and tight.the battery looks fine and it starts up good,what else should I do?? ps it runs like a deere ,lol Harry,Ca:confused:
/ charge light staying on ??? #2
Harry,
You might start by cleaning the battery ground cable. Take it loose from both the battery and the tractor frame.
Bruce
/ charge light staying on ??? #3
If it keeps starting good ,look at the holding relay. I think that model has an external holding relay for the warning light. If the battery does go dead, replace the current limiter. The limiter is one of the few parts that fail more often.
/ charge light staying on ??? #4
See if it's charging.
/ charge light staying on ??? #5
As Norm said, the first thing to so is find out if the alt/reg is working. What is battery voltage when not running and then what is voltage when running? Fully charged battery should see 12.7V. When running at speed should see something like 14.25V.
Thanks for the reply,okay I m not that smart when it comes to the motor stuff,so the quetion I have is how do I check to see if the battery is charging and if the alt/reg is working ,and were is the limiter anyway on the tractor ,sorry for the stupid questions ,thanks .ps what do I get to test this stuff at the auto store ."no I am not a blonde":)
/ charge light staying on ??? #7
get you a volt meter ,set on 12 volts dc connect the red wire from the volt meter to the pos side of the batt- connect the blk wire from the volt meter to the neg side of the batt. with the engine running you should get somewhere around 14 volts. maybe a little more . If not have your alt. checked at alt. repair shop.
hope this helps
/ charge light staying on ??? #8
Don't mean to nit pik but you'll need to set the voltmeter to the setting higher than 12 volts to correctly measure what you hope will be 14 something. The meter might not like 14 something volts coming thru on the 12 volt setting.
/ charge light staying on ??? #9
It won't matter if it's digital meter...........
I think he was merely saying put it on a scale that will read the 12v easily.
Harry, you can buy inexpensive multi - meters from a number of sources - Sears, Radio Shack etc. It's a great help when trying to figure out why something's not working, and on 12 V DC systems very easy to use. The black lead clips to a ground, and the red lead to whatever is supposed to be showing voltage. If it's there, it'll show on the meter, if not - that will show too.
When checking the alternator, clip the black lead to the - post on the battery and the red to the + . Before you start the engine, you should show battery voltage from 12 to about 12.75, after starting the engine and at a fast idle, if the alternator's working the battery should show 14v + or so, if not, I'd take the alt off to a shop to be checked. Most better auto parts stores can check it for you, most will do it for free.
/ charge light staying on ??? #10
I don't know if this will apply to the tractor (guessing it will), but I just had to replace the alternator in my car. However, it didn't start discharging until after it was warmed up. Since you are getting the light though, it sounds like yours is out completely. But, just in case, if everything checks out initially, you might want to check it again after 10 min or so. The voltmeters are handy things to have. You can also use them on the AC in your house just to make sure an outlet or light really does not have current before you change it.
/ charge light staying on ??? #11
Correct dave, A digital meter will be within a range . Mine starts out at 20 & goes to 200 on the dc scale. If you have a harbor frieght store in your area, they offer these meters real cheap !
/ charge light staying on ??? #12
I went through this with my YM3000. But it was the Voltage reg. Deere wanted 180 then 118 for 2 similar ones. I carried it to a friends starter shop and he got some numbers and called back with a price for an electronic regulator no contacts was 26.50 for the part and 17.00 for overnite shipping.
John Deere 10KW Generator (A64912)
John Deere 10KW...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
PORTA POTTY (A67714)
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
