Charge Light Staying On - Redux
   / Charge Light Staying On - Redux #11
Tom_Veatch said:
The 6 wire, rectangular plug is the right interface, and I might want to talk to you about a replacement if/when I decide this thing is beyond hope. Right now, 'though, it seems my speaking sternly to it earlier today had the right effect. The charge light was behaving itself and the voltage across the battery was gradually building back up from the starting drain when I ran it up a few minutes ago. (I don't suppose the box/package/etc. they come in has a wiring diagram/schematic attached, does it?)
I wouldn't be too concerned about it for an $85 regulator, as long as it is charging. Is the fan belt tight enough?
   / Charge Light Staying On - Redux #12
It's good that you don't suppose so.;) They don't.
Yep. In fact as a part of my "end of season" maintenance, I replaced the fan belt, which was beginning to show signs of deterioration, and the lower and bypass coolant hoses.
Bypass hose was beginning to show fabric on the outside of the "U" and the lower hose had a groove worn in it from contact with the fan belt. I think either (or both) the old belt was slightly too short or the old hose was slightly too long. There's plenty of clearance with the new parts.
2023 BOBCAT 776R SERIES SKID STEER (A51242)
2023 BOBCAT 776R...
LOT LOCATIONS (A52141)
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
