Changing tractor attachments safely. Is a backhoe subframe in the way?
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #1
Green Acres Homestead
Veteran Member
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
With the Kubota backhoe subframe you have to be careful installing implements. There is very little room between lift arms and the backhoe main hydro line. I already broke the hose that feeds the backhoe. Here is my logging winch install that shows this short coming.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #2
Bend the female hose bracket up so the hose does not rub on the bolt and then move the bracket to the outboard side of the backhoe subframe. You may gave to use a stud and nut instead of the original bolts as the ROPS might be too close. I did that on my MX4800.
Thanks. That is make sense. I will give that a go.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #4
Let us know how it goes.
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
POLARIS RANGER 4X4 PROSTAR UTV (A51406)
POLARIS RANGER 4X4...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
