Changing tractor attachments safely. Is a backhoe subframe in the way?
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
With the Kubota backhoe subframe you have to be careful installing implements. There is very little room between lift arms and the backhoe main hydro line. I already broke the hose that feeds the backhoe. Here is my logging winch install that shows this short coming.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #2
Bend the female hose bracket up so the hose does not rub on the bolt and then move the bracket to the outboard side of the backhoe subframe. You may gave to use a stud and nut instead of the original bolts as the ROPS might be too close. I did that on my MX4800.
Thanks. That is make sense. I will give that a go.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #4
Let us know how it goes.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
MISC CABINET PARTS (A54757)
MISC CABINET PARTS...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
