Changing tractor attachments safely. Is a backhoe subframe in the way?
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
With the Kubota backhoe subframe you have to be careful installing implements. There is very little room between lift arms and the backhoe main hydro line. I already broke the hose that feeds the backhoe. Here is my logging winch install that shows this short coming.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #2
Bend the female hose bracket up so the hose does not rub on the bolt and then move the bracket to the outboard side of the backhoe subframe. You may gave to use a stud and nut instead of the original bolts as the ROPS might be too close. I did that on my MX4800.
Thanks. That is make sense. I will give that a go.
   / Changing tractor attachments safely. Is a backhoe subframe in the way? #4
Let us know how it goes.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
UNUSED RAYTREE RMBD72S 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
More info coming soon! (A53421)
More info coming...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
