Changing tire sizes.
/ Changing tire sizes. #1
spider22
Kubota L3130
A friend has 180/85D12 tires on the front of a Kubota. That size is hard to find. The info I get for that size is 24.1" high with a rolling circumference of 71. He has found tires in size 600-12 that are 23" high with a rolling circumference of 69. Would it be OK for him to use that size for the 2 fronts or would it mess something up on a 4x4 tractor?
/ Changing tire sizes. #2
We can get you a 180/85D12 Titan Tru Power, $198.00 each + shipping. Call 419-335-7010 8am-5pm EST, Mon-Fri. Ask for Ed
/ Changing tire sizes. #3
Check the lead lag ratio/RCI. If it's still within the acceptable percentage (1% to 5%), you should be fine.
/ Changing tire sizes. #4
Most tractors have some front lead, meaning in 4wd the front tires are covering just a tiny bit more ground than the rear. Putting a smaller tire on the front will reduce (or eliminate) that lead, which is better for straight line... My $0.02 is that he'd be fine.
FWIW, I gave my tractor slightly more lead with a tire change and I like it better because most of my 4x4 work is loader work, with a lot of turning. I get no binding at about 1/3 of full lock instead of closer to straight. More lead makes it turn without so much crabbing in 4wd, but going straight I can see the front tires pulling more... I just don't use 4wd going straight on harder surfaces where it isn't needed anyway...
Good luck!
/ Changing tire sizes. #5
I have a Ford 4500 . I have replaced one of the tires with trelleborg 440/70/24 . I just use for moving hay and mowing . it has been on as a mismatch for over a year. I was just told that it will ruin the seals etc. Is this true. It is an old tractor 1967-1975 It is never on hard sueface
/ Changing tire sizes. #6
Assuming the new tire is close in size to the old tire, you're not going to cause any problems running a slight mismatch. No seal problems for sure. (What fool suggested seal problems from a slight tire size difference? Unless the tractor is always leaning 10° to one side, I don't see how any seal would care...) Run it!
/ Changing tire sizes. #7
The reason for the front "lead" of a few percent is that keeps the rears from pushing the front around a curve and lets the fronts pull the rears around the curve.
213064 (A64276)
213064 (A64276)
3142 (A63117)
3142 (A63117)
2025 KENWORTH T880S DUMP TRUCK (A63276)
2025 KENWORTH...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
2016 Ford Fusion Hybrid Sedan (A64557)
2016 Ford Fusion...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
