Changing tire size on a four wheel drive tractor
   / Changing tire size on a four wheel drive tractor #1
Rob C
Lusk Wyo
Mcormick CX105
The front tires on my Mcormick tractor don't seem to be heavy enough to handle a 1400lb round bale.I would like to put some heavier duty tires on but it is a 4 wheel drive. It has 11.2-24 8 ply Good year tires
   / Changing tire size on a four wheel drive tractor #2
Have you considered foam filling the tires?
As long as the other tires have the same circumference it should not be a problem.
   / Changing tire size on a four wheel drive tractor #3
If you put a taller on the front, you need go taller on the back by the same %
   / Changing tire size on a four wheel drive tractor #4
8 ply should be enough most the full size back hoes around here only have 8 ply tires front and back. I put 12 ply on mine to help resist rock damage.
   / Changing tire size on a four wheel drive tractor #5
I have 11.2-24 tires on my jd and can easily handle 1400lbs no problem. How much air pressure are you running in them?
   / Changing tire size on a four wheel drive tractor #6
My dealer told me it is critical to maintain the same ratio in the diameters between the front & back on a four wheel drive or the tranny will "pop".
I've seen lengthy threads on the tractor forums on just this topic.
   / Changing tire size on a four wheel drive tractor #7
Sounds like low air pressure. 8-ply should be plenty
   / Changing tire size on a four wheel drive tractor #8
I have 9.5 x 24 - 6ply @ 30psi and they don't get "squishy" looking until I carry over 2100 lbs with the grapple. Run your fronts up to max pressure as indicated on the tire sidewall.
   / Changing tire size on a four wheel drive tractor #9
Are they radials? They flex more than bias ply, they also give a lot more traction...
I agree though, air them up!!
SR
   / Changing tire size on a four wheel drive tractor #10
Might as well throw my hat in the ring too. Air em up. Cheap solution, no problems generated, no work involved, right answer.
3 PT QUICK HITCH (A54756)
3 PT QUICK HITCH...
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
MAHINDRA 1635 TRACTOR (A54756)
MAHINDRA 1635...
John Deere BD1108 (A50123)
John Deere BD1108...
