Changing the oil filter on my BX2360
   / Changing the oil filter on my BX2360 #1
mccash40
Adirondacks, NY
kubotabx2360
This will be my third oil change and I need suggestions. The first 2 changes went great. I purchased one of those ratchet filter removers and it worked fine. Today when I went to remove the filter, the remover just slipped around the filter. I went to the auto parts store and bought a ring remover, but I can't get it far enough in to turn. Too many wires, etc. and the filter seems to be on really tight. It's a factory Kubota filter. Any ideas?
   / Changing the oil filter on my BX2360 #2
For many years I've used a large jaw channel lock pliers /or slip lock pliers.[what ever you want to call them] with great success, on stubborn filters. The BX has room to use them as this is what I use on mine.
Thanks Massey Driver. I found another thread with some excellent ideas on removal. The lock pliers seem like the way to go. Oils well that ends well. :laughing:
   / Changing the oil filter on my BX2360 #4
I've had good luck with something like this for my BX24, GR2120, and generator oil filters. Not sure what it's called. Cap wrench, maybe?
Z.
   / Changing the oil filter on my BX2360 #5
   / Changing the oil filter on my BX2360 #6
I now use this on all our vehicles. Works great in tight quarters.
   / Changing the oil filter on my BX2360 #7
If all else fails you need to punch a hole through both sides and insert a screwdriver. Twist carefully and slowely as the filter will start to self destruct.
Well, that ordeal is over. Filter is off and oil is changed. I used a large channel plier and was able to fit it in enough to turn it. Just in time. It snowed 2" last night.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 KUBOTA RTV...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
Informational Lot - Shipping (A51039)
Informational Lot...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
