Changing the oil filter on my BX2360
   / Changing the oil filter on my BX2360 #1
mccash40
Adirondacks, NY
kubotabx2360
This will be my third oil change and I need suggestions. The first 2 changes went great. I purchased one of those ratchet filter removers and it worked fine. Today when I went to remove the filter, the remover just slipped around the filter. I went to the auto parts store and bought a ring remover, but I can't get it far enough in to turn. Too many wires, etc. and the filter seems to be on really tight. It's a factory Kubota filter. Any ideas?
   / Changing the oil filter on my BX2360 #2
For many years I've used a large jaw channel lock pliers /or slip lock pliers.[what ever you want to call them] with great success, on stubborn filters. The BX has room to use them as this is what I use on mine.
Thanks Massey Driver. I found another thread with some excellent ideas on removal. The lock pliers seem like the way to go. Oils well that ends well. :laughing:
   / Changing the oil filter on my BX2360 #4
I've had good luck with something like this for my BX24, GR2120, and generator oil filters. Not sure what it's called. Cap wrench, maybe?
Z.
   / Changing the oil filter on my BX2360 #5
   / Changing the oil filter on my BX2360 #6
I now use this on all our vehicles. Works great in tight quarters.
   / Changing the oil filter on my BX2360 #7
If all else fails you need to punch a hole through both sides and insert a screwdriver. Twist carefully and slowely as the filter will start to self destruct.
Well, that ordeal is over. Filter is off and oil is changed. I used a large channel plier and was able to fit it in enough to turn it. Just in time. It snowed 2" last night.
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
STORAGE FEES (A51219)
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
Toro Zero Turn Mower (A50322)
Toro Zero Turn...
