Changing out the mmm
   / Changing out the mmm #1
flemdog
INDIANA
JD 4310
I am leaning on purchasing a TC29D or B2910. I seem to take the mmm on and off alot. One very important consideration in buying one of these cuts is the swabbing of the mmm. Can anyone share how easy of hard and about much time it takes to change it out. Also, if anyone would care to describe the operation, I sure would appreciate it. Thanks for the input.
   / Changing out the mmm #2
For a 914A on a TC25D;
1. Raise front of tractor with FEL.
2. Lower deck to ground
3. Pull 4 safety/cotter pins
4. Pull 4 pins
5. Disconnect driveshaft
6. Slide deck from underneath tractor.
Total time: 5 minutes
   / Changing out the mmm #3
If u don't have FEL use 1' long RR ties and pull front wheels up on them AFTER taking out the front pins.
I do this on my 35D and mower comes right out.
Less than 5 minutes, more like 3 in the floor is clean.
   / Changing out the mmm #4
I have a 24D w/ the 914A 60"MMM, I personally can take it off and put it on faster than I can attach my 4' KK rotary. As someone said 4 pins and it is off. Does make it easier if you lift the front w/ FEL or blocks. 5 minutes on or off is probably on the high side. Biggest problem is I do mine on grass and it can be tough to slide under usually not a problem sliding it out though.
   / Changing out the mmm #5
I have a Kubota B2910 and bought a NH TC24D for mowing!
2003 INTERNATIONAL 7600 6X4 DUMP TRUCK (A51247)
2003 INTERNATIONAL...
Deere 331G (A50123)
Deere 331G (A50123)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
2012 GREAT DANE 53FT REEFER TRAILER (A53426)
2012 GREAT DANE...
