Changing out the mmm
   / Changing out the mmm #1
flemdog
INDIANA
JD 4310
I am leaning on purchasing a TC29D or B2910. I seem to take the mmm on and off alot. One very important consideration in buying one of these cuts is the swabbing of the mmm. Can anyone share how easy of hard and about much time it takes to change it out. Also, if anyone would care to describe the operation, I sure would appreciate it. Thanks for the input.
   / Changing out the mmm #2
For a 914A on a TC25D;
1. Raise front of tractor with FEL.
2. Lower deck to ground
3. Pull 4 safety/cotter pins
4. Pull 4 pins
5. Disconnect driveshaft
6. Slide deck from underneath tractor.
Total time: 5 minutes
   / Changing out the mmm #3
If u don't have FEL use 1' long RR ties and pull front wheels up on them AFTER taking out the front pins.
I do this on my 35D and mower comes right out.
Less than 5 minutes, more like 3 in the floor is clean.
   / Changing out the mmm #4
I have a 24D w/ the 914A 60"MMM, I personally can take it off and put it on faster than I can attach my 4' KK rotary. As someone said 4 pins and it is off. Does make it easier if you lift the front w/ FEL or blocks. 5 minutes on or off is probably on the high side. Biggest problem is I do mine on grass and it can be tough to slide under usually not a problem sliding it out though.
   / Changing out the mmm #5
I have a Kubota B2910 and bought a NH TC24D for mowing!
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
UNUSED LONCIN 90 PLATE COMPACTOR (A51248)
UNUSED LONCIN 90...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
