Tires changing my first flat tire
/ changing my first flat tire #1
marci
Nebraska
cub cadet 1024
I just walked out to start mowing when I noticed the right front tire of my Cub Cadet lt1024 has a flat..really flat. Since I've only owned the tractor about a month I don't want to wreck something as I attempt to remove the tire. I've spun the hubcap, pulled it, tried to pry it off (without too much force). How do I get that thing off and then what can I expect in regards to removing the tire and wheel. The parts list is not much help to me.
/ changing my first flat tire #2
If the rubber is still good, take the wheel to a tire shop & have them pop in an inner-tube in for you.
G/luck
Joel
/ changing my first flat tire #3
Marci, did you mean an LT1042 instead of LT1024? It's been awhile since I had to remove one of those, but I think you simply have to pry that cap off, and it does take a little force, then you'll find a cotter pin to remove, a big washer to slide off, and then pull the wheel off. And remember, my experience is dated, so I could be way off base.
Yes, you are correct...I must have been a little dyslexic last nite. /forums/images/graemlins/smile.gif I was afraid to put too much force onto that plastic little hubcap but will go ahead and do it this evening. I wasn't sure if there was something on the backside holding it on. Cotter pin I can handle so it looks like it should be pretty staight forward. Thanks for your quick response!
/ changing my first flat tire #5
I got a flat on my 2042 the second time I mowed with it. It was a Russian Olive thorn. I plugged it with one of those tubeless tire repair plugs and it hasn't leaked since. Didn't even have to take it off the tractor that way.
/ changing my first flat tire #7
I had a multitude of flats when I first moved to our new place. We had several large locust trees (that have since been removed) and mowing around them was dangerous!!!!! I keep my tires filled with Gunk (green stuff you can get at most Home Depot/Lowes) and it works like a charm. In a flat tire just take out the valve stem (each bottle comes with a tool) and put in the whole bottle. Fill the tire with air and give it a spin. I have pulle some VERY large thorn out only to see the holes almost immedieatly filled with green Gunk. No more flats for me.....
/ changing my first flat tire #8
If you have to take the tire off the rim it would be much easier to take it to a mower shop and let them do it.
Because of the small diameter of the tires, they don`t have much stretch.
They are a SOB to get off and on.
I wrestled with one for two hours one time and it finally kicked my butt.
/ changing my first flat tire #9
Leave the tire where it is, go get a bottle of "slime" remove the valve stem core, fill it up with slime, put valve stem core back in, air it up and be done with it
/ changing my first flat tire #10
I'm with Duc on this one, although my favorite product is Fixaflat. I buy it two and three cans at a time. You don't even need to remove the core, just thread it on the stem and it airs/slimes the tire right up.
The only thing I wasn't using it on was car tires because of balance and the mess it caused if you had to dismount the tire. The last slow leak I had, I stopped at three garages and none could check the tire so I injected a can of Fixaflat, that was 8 months ago, no balance issues whatsoever. I'll warn the person changing the tire if I get to that point. I hear it's real messy!
I joke with my brother in law that a true measure of a mans success is how many pneumatic tires he has, I think I'm at 72! There might be a flaw in my thinking!
Curt
/ changing my first flat tire #11
I would recomend against using "Fix-a-Flat". Most tire shops will not work on tires that have had it installed. It tends to weld the tires to the rims and is almost impossible to remove all of it once installed. It dries to a concrete hard substance on the rim and don't ever plan on getting a patch to stick to the rubber once its installed. Fix-a-Flat is good for one thing. You have a flat out on the road, fill your tire with the stuff and drive it far enough to get to a tire shop. Have them remove it as soon as possible before the stuff dries.
I would suggest using the gel type sealants like were mentioned elsewhere in this thread. They don't dry to a rock hard substance. Just be cautious with some of them. Some tend to sour over time and rust out the rims.
Here was a very good thread on tire sealants. http://www.tractorbynet.com/forums/parts-repairs/100282-tire-slime.html?highlight=tire+sealant
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
3147 (A63117)
3147 (A63117)
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
17394SFL (A61568)
17394SFL (A61568)
Case CX75C (A62177)
Case CX75C (A62177)
