Changing my 425’s Hydraulic fluid.
   / Changing my 425’s Hydraulic fluid. #1
CreativeGuy
Newport, Oregon
PowerTrac PT-425
Greetings, I’ve just reached 200 hours on “Artie” my PT 425. While I have changed the hydraulic fluid filter every 50 hours, I’ve not changed the fluid itself. It still looks pretty clear. Can I go with just another filter change, or should I really be changing out the fluid as well?
   / Changing my 425’s Hydraulic fluid. #2
That's gonna be up to the other folks and you. ;)
Personally, I've never changed the hydraulic fluid in my 2001 PT425. I've added a quart every 50 hours to makeup for filter change. I've got 1000 hours on it, so I've added 5 gallons of oil to it over the years, plus a few more for hose leaks/replacements. I've always added Mobil1.
We'll see how it goes. 🙃
   / Changing my 425’s Hydraulic fluid. #3
Change it. You'll sleep better. Lol.
If it's clear the mossroad method should be fine. If it's low, milky at all find/fix where the leak or water is coming from and change (or process) the fluid.
The mods recommended like adding a tank magnet etc are good advice
Thanks,
I’ll continue change the filter and add as needed.
Cheers,
Steve
Artie
   / Changing my 425’s Hydraulic fluid. #5
After seven or eight years, I find the oil in my PT gets darker, thins, and affects the hillclimb ability. If the bottom of the tank is still shiny with a bright flashlight, I would not sweat it. If your oil is still clear, and the viscosity looks good, I would go for the patented @MossRoad method.
All the best,
Peter
   / Changing my 425’s Hydraulic fluid. #6
I have had my machine for 15 years and have yet to change the oil. That said just wait. You will rupture a hose and it will get changed automatically for you.
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
UNUSED FUTURE FT-HJ6 40' METAL STORAGE SHELVES (A57193)
UNUSED FUTURE...
Metal Sunfower Lawn Art (A55853)
Metal Sunfower...
2017 Ford F550 Crew Cab Service Truck (A56858)
2017 Ford F550...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
UNUSED FUTURE FT-CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
