Changing my 425’s Hydraulic fluid.
   / Changing my 425’s Hydraulic fluid. #1
CreativeGuy
Newport, Oregon
PowerTrac PT-425
Greetings, I’ve just reached 200 hours on “Artie” my PT 425. While I have changed the hydraulic fluid filter every 50 hours, I’ve not changed the fluid itself. It still looks pretty clear. Can I go with just another filter change, or should I really be changing out the fluid as well?
   / Changing my 425’s Hydraulic fluid. #2
That's gonna be up to the other folks and you. ;)
Personally, I've never changed the hydraulic fluid in my 2001 PT425. I've added a quart every 50 hours to makeup for filter change. I've got 1000 hours on it, so I've added 5 gallons of oil to it over the years, plus a few more for hose leaks/replacements. I've always added Mobil1.
We'll see how it goes. 🙃
   / Changing my 425’s Hydraulic fluid. #3
Change it. You'll sleep better. Lol.
If it's clear the mossroad method should be fine. If it's low, milky at all find/fix where the leak or water is coming from and change (or process) the fluid.
The mods recommended like adding a tank magnet etc are good advice
Thanks,
I’ll continue change the filter and add as needed.
Cheers,
Steve
Artie
   / Changing my 425’s Hydraulic fluid. #5
After seven or eight years, I find the oil in my PT gets darker, thins, and affects the hillclimb ability. If the bottom of the tank is still shiny with a bright flashlight, I would not sweat it. If your oil is still clear, and the viscosity looks good, I would go for the patented @MossRoad method.
All the best,
Peter
   / Changing my 425’s Hydraulic fluid. #6
I have had my machine for 15 years and have yet to change the oil. That said just wait. You will rupture a hose and it will get changed automatically for you.
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2015 FREIGHTLINER CASCADIA DAYCAB (A55745)
2015 FREIGHTLINER...
2005 Kaufman Trailers Car Hauler Trailer (A55788)
2005 Kaufman...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
