Changing my 425’s Hydraulic fluid.
   / Changing my 425’s Hydraulic fluid. #1
CreativeGuy
Bronze Member
Newport, Oregon
PowerTrac PT-425
Greetings, I’ve just reached 200 hours on “Artie” my PT 425. While I have changed the hydraulic fluid filter every 50 hours, I’ve not changed the fluid itself. It still looks pretty clear. Can I go with just another filter change, or should I really be changing out the fluid as well?
   / Changing my 425’s Hydraulic fluid. #2
That's gonna be up to the other folks and you. ;)
Personally, I've never changed the hydraulic fluid in my 2001 PT425. I've added a quart every 50 hours to makeup for filter change. I've got 1000 hours on it, so I've added 5 gallons of oil to it over the years, plus a few more for hose leaks/replacements. I've always added Mobil1.
We'll see how it goes. 🙃
   / Changing my 425’s Hydraulic fluid. #3
Change it. You'll sleep better. Lol.
If it's clear the mossroad method should be fine. If it's low, milky at all find/fix where the leak or water is coming from and change (or process) the fluid.
The mods recommended like adding a tank magnet etc are good advice
Thanks,
I’ll continue change the filter and add as needed.
Cheers,
Steve
Artie
   / Changing my 425’s Hydraulic fluid. #5
After seven or eight years, I find the oil in my PT gets darker, thins, and affects the hillclimb ability. If the bottom of the tank is still shiny with a bright flashlight, I would not sweat it. If your oil is still clear, and the viscosity looks good, I would go for the patented @MossRoad method.
All the best,
Peter
   / Changing my 425’s Hydraulic fluid. #6
I have had my machine for 15 years and have yet to change the oil. That said just wait. You will rupture a hose and it will get changed automatically for you.
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
