Changing Mig Wire
/ Changing Mig Wire #41
I struggled understanding a MIG welder when I first bought one. The wire speed determines the AMPs of the welder. A dirty liner will slow the feed of the wire or make it unreliable. The welder will totally frustrate you. Very important to have a clean liner. Also, very important to not "kink" your gun feed. I always make sure I'm letting the feed lay in a relaxed position and not bent sharply around anything. I use a 15' feed. If kinked or bent sharply it won't weld for crap.
/ Changing Mig Wire #42
2# spool is small enough you can hold it in your left hand and feed the end into the liner before attaching it to the feeder.
What gets me is how some of you can't handle being told how your problem isn't a problem because we've already found ways to make it not a problem but you seem bent on insisting that since you couldn't figure it out that somehow we're demeaning you. We've given you the solution, but you still want to whine about it.
Just being blunt and sincere like someone's sig line claims they are. ;)
What gets me is the know it all goofs that just because they have not experienced an issue think it does not exist or that they are omnipotent mechanical masters...guess again goofy...!
And BTW buster...you have not told me anything of any value I did not already know
/ Changing Mig Wire #43
You want some fun? Try a 2# spool of .035 309 SS!
There's nothing short of deep cleaning or liner replacement that would get me to pull my gun off the feeder. That O-ring at the mount is responsible for keeping your shielding gas going out the right end of the hose, and every time you pull it off is one more opportunity to ruin that seal and possibly introduce air into your shielding gas via venturi suction.
My intention was never to get anyone's goat or panties wadded, but to explain that I wouldn't even consider removing the gun to change wires. Honestly, the thought of such a method had never crossed my mind. There's no sense to it IMO.
/ Changing Mig Wire #44
The last welds I made:
Post yours. :rolleyes:
/ Changing Mig Wire #47
post what? a picture of an unorganized mess? LoL...!
Get a clue or some help...!
I can't find good help. Last guy I tried to hire wanted to pull the engine to change the alternator. Any relation of yours? :laughing:
/ Changing Mig Wire #48
I can't find good help. Last guy I tried to hire wanted to pull the engine to change the alternator.... :laughing:
I have no doubt you actually tried to employ the guy...obviously it makes perfect sense...:thumbsup:
/ Changing Mig Wire #49
I see your deductive reasoning is on par with your MIG electrode threading skills. :D
/ Changing Mig Wire #51
I like the way you fixed that leaking rod seal for good.
:laughing:
Bruce
Not quite. :laughing:
I did use the drop from shortening the rod to extend the fixed eye though. The adjustable draft sensing doesn't leave much room for the cylinder at the tractor, so it needs to be poked out or you lose the use of the bottom holes (and all your automaticness).
/ Changing Mig Wire #52
Arkydog, got a chuckle reading your post, my problem is when I install a new roll and when running the wire through the rolls, sometimes the wire starts to unravel from the reel. Talk about problems! Best regards, Bob
/ Changing Mig Wire #54
Been there, done that. I put a piece of painters tape across the wire. That eliminates the unraveling.
/ Changing Mig Wire #55
What was there to deduct?...I posted an observation based directly on what you had said...
BTW...deduct this:
01000010 01101001 01110100 01100101 00100000 01101101 01100101 00100000 01111001 01101111 01110101 00100000 01110010 01100101 01110000 01110101 01100111 01101110 01100001 01101110 01110100 00100000 01100001 01110011 01110011 00100000 01110111 01101001 01110000 01100101
/ Changing Mig Wire
rhunt, i appreciate your reply. glad you brought it up.
what i do first is to firmly tighten the spool tension. this keeps the wire from birds nesting.
then with both hands, one on spool, other holding wire, i turn spool and advance wire at same time.
with the wire hand i feed the first guide and at the same time turn the tensioned spool and advance the wire into the first guide and then the already the opened rollers(no need to change roller tension setting using same size dia. wire).
close the roller tensioner, remove gun if already haven't, turn down voltage and up wire speed
remember to leave electrical plug on gun plugged in, pull trigger advancing wire and then into liner. install gun in machine, remove gun tip, str. gun out and advance wire thru gun and out.
hope this help for those that have to remove the gun on multi use machines like those with spool funs for aluminum.
/ Changing Mig Wire #57
Thanks for the advice. Best regards, Bob
/ Changing Mig Wire #58
BTW...deduct this:
{Btw: this is all binary code which translates to "Bite me you repugnant *** wipe" *** is a synonym for "butt" }
Still wondering how good of weldor you are to be giving advice about it? Show us some beads. :D
Ad hominem is a really weak position to argue from btw. ;)
/ Changing Mig Wire
"Bite me you repugnant *** wipe" *** is a synonym for "butt" btw
jim timber, why are so nasty, this was a thread to inform other people that might have problems spooling the wire in most any kind of mig welder, not to have everybody that reads this thread to show what an ***** you are.
/ Changing Mig Wire #60
/pine actually started this one...... :(
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2021 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2021 Posi Track...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
