Changing liner in a mig gun ? ? ?
   / Changing liner in a mig gun ? ? ? #1
Chain Bender
Kubota L3200
I finally have gotten used to welding with my Handler 140 and I absolutely love it. BUT, now I'm starting to have some troubles with the wire feed.
I know I've got the feeder wheel set to the appropriate wire size. I've got just enough tension on it that it will feed at the rate the machine is set on. Usually 55-60. Will be welding along feeling good about the welds. Even the upside down ones and the ones straight up and down. Almost looks like I know what I'm doing. THEN all of a sudden I get a birds nest at the feeder wheel and all stops. Cut, pul wire, cur again, sand paper the leading point of the wire before I feed it into the gun. Runs great for a few minutes and then comes another birds nest.
When I first got the machine I was doing a lot of aluminum wire welding. That was a feat in it self. But I finally mastered it and made some really nice ladder deer stands. Have heard that aluminum wire is particullary rough on regular liners.
That's the only thing I can think of that would make this machine jam up as much as it does. I ran almost all the way through a small spool of 0.030" wire with out a problem. Now I've got a big spool on the roller and am having all the problems. Wire isn't rusty. Pretty clean. Tension on the spool is plenty tight.
Any one have any suggestions? How hard is it to replace a liner? I'm thinking about replacing the standard one with a teflon liner. Will that help at all?
thanks in advance for any suggestions,
CB
   / Changing liner in a mig gun ? ? ? #2
Pretty cheap and easy to put in. While your in the welding place get some of those little felt "wipers" that go on the wire just before the lead.
   / Changing liner in a mig gun ? ? ? #3
I cant remember the exact term, but I know there is an adjustment on the spool arbor, that prevents it from free spinning after the wire feed stops. If that is too loose, and you have a fast enough feed speed, it will often birds nest when you stop feeding. Try tightening that before you buy a new liner, it is worth a try. The other thing I can think of is the tip might be too dirty/worn, and that is jamming it up. Try a new tip and that adjustment, and see if that solves it.
   / Changing liner in a mig gun ? ? ? #4
Have you tried blowing the gun / liner out? I like to use the oxygen bottle without gauge. Remove the gun from the welder, remove the contact tip, place the end of the gun that goes in the welder on the opening of the oxygen bottle and crack the valve.
An ear plug works well for a wire wiper too. What ever you do don't buy the wipers with the lube on them!
   / Changing liner in a mig gun ? ? ? #5
I have had the problem you describe on occasion with my small lincoln, it happenes when the spool slips on the spindle, that's where i would look first. As far as changing your liner its quite easy ,but before i changed it i would go to your welding supply store and buy some lube pads for the wire, i use them on all three of my wire feed welders. i find that if i don't use the welder regularely the liners will get sticky causing the weld puddle to spatter.
By the way now that you are using your welder for steel wire and not aluminum, if you want to go back to welding aluminum you WILL have to change your liner as AL doesn't like to be contacted by any pieces that have been used for steel,it tend's to corrupt the weld......craig
   / Changing liner in a mig gun ? ? ? #6
I agree with Shield Arc. Don't use those felt "lubricators" for your wire. A buddy with the same machine I have has had the felt come apart and clog his liner. I have a 185 and I assume yours is similar but a little smaller. I would make sure the entire drive assembly is clean and lubricated per the owners manual. I've had to replace my rollers a couple times but I've never had to replace the liner, although I only run .035 flux core with mine and haven't done any aluminum welding.
kj
   / Changing liner in a mig gun ? ? ? #7
Another thought, when you run aluminum, what drive rolls do you use? Do you have a set of U-groove rolls, or are you using the V-groove rolls for Mig welding? Please don't tell me you're using serrated drive rolls!:eek:
   / Changing liner in a mig gun ? ? ? #8
If the Bird nest is after the drive rolls where the wire goes in the gun, You can loosen the feed pressure so that it will spin instead of bird nesting. Easier to unstick a burn back than the hassle of a bird nest. You still have to be aware that your gun still should be kept fairly straight. The more you weld with it while it's twisted, The more friction there is between the wire and the liner. This will scrape a little coating off the wire and cause premature liner failure. But...If you have been running Aluminum through the steel liner, It's probably got some Aluminum fouling in it. If you do buy a new liner, Buy a size larger than the wire you use.
   / Changing liner in a mig gun ? ? ? #9
Another thing that will cause bird nesting, is too big of a gap between the drive rolls, and the gun. I'm not familiar with the Handler 140 at all, so I don't know if you can adjust the guide tubes or not. Maybe as simple as jamming the gun in further. I always try to have the gun / guide tubes as close to the drive rolls as possible, especially with soft / small diameter wire.
Thanks to all for your responses.
Here is what I can tell you as fact and not presumptions.
Birdnest is happening between feeder wheel and where the wire goes into the gun. It's only about 1/2 - 3/4" space there.
Spool is definitely tight enough to stop once the trigger is released.
Not using serated feed wheel.
never have blown out the gun. Sounds like it must be time.
Don't use/have lube pads, but do use the nozzel lube sometimes.
Understand about loosening up the tension on the feed wheel to bare minimum and keeping the gun hose as straight as possible. That was particullary true with the aluminum wire. When tyhrough great pains to keep it as straight as possible.
Will blow out the lne today and report back on the problem.
Thanks much for all suggestions.
CB
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2023 UNVERFERTH 632 LOT NUMBER 148 (A53084)
2023 UNVERFERTH...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
