Dirt Moving Changing hydraulic line on T5
/ Changing hydraulic line on T5 #1
lorsman
Terramite T5C
Hi, I would like to know if anyone knows the easiest way to remove the hydraulic hose for the bucket on a terramite T5C. I traced the hose back all the way to the rear control panel. That's a lot of sleeves, bends,curves and other obsticales.Does somebody have a trick they used to change one or one like it. The hose is about 8 ft long or so ?
I just changed the front loader hose last week, thought that was not so tuff, now this! Since I changed fluid, oil and filters leaks are poping up. Need the Mache quick, the yards tore up for drainage work and stoms keep popin up durrin this heatwave.
Thanks inadvance!
lorsman
/ Changing hydraulic line on T5 #2
Changing the hoses for the back hoe is pretty straight forward. They are all routed through to the rear control valves through the bottom. Loosen the ends and pull the hose through. You can remove the floor plate under the seat to help when doing the repair. It is strange that since you changed oil that the hoses are failing?????? Did you use 15W-40 motor oil or hydralic fluid?
