changing HST fluid
/ changing HST fluid #1
bstrom
Platinum Member
Maine
kubota b2620
Well I am going to change my HST fluid and filter on my B2620 this weekend at almost 100 hrs after reading the thread about the Kubota manual screwup telling you not to change it after 50hrs.
I'm new to this - where is this screen everyone is talking about? I just see a filter and drainplugs in the manual but apparently the manual is not to be trusted that much.
/ changing HST fluid #3
A big bolt (forget the size) between the tranny and the left wheel. Has an o-ring, so watch that...Clean it out with carb or brake cleaner and allow to dry..Then replace. Make sure the o-ring isn't dry when re-installing.
Thanks guys.
Yeah, I never found a screen. 3 drain-plugs on the transmission, 2 on the front axle. For those attempting it for the first time you really need an offset funnel or one with a tube at least to get the SUDT back in there or you will have a mess. It takes around 5 gallons to do the trans and front end.
My b2620 had 98 hours on it. The stuff was as clean as a whistle, if there were metal filings, boy I sure didn't see any. My personal and unprofessional opinion? A waste of time, money and resources. Just change the filters until 400 hours. Just my take on it. I think Kubota said 400 hours because people were complaining about the expense. I don't think it was a mistake they made it 400 hours but thats just my theory you make up your own. I think it cost me around 120 bucks with the filters and plastic offset funnel. Receipt must be in the truck
/ changing HST fluid #7
Thanks for sharing your experience and opinion on it. It's certainly not the money.
Well, I guess I was thinking if you add the 120 bucks to the cost of the parts for the free labor 50 hr maintenance that dealers offer, people might scream after they are already making a tractor payment. I'm thinking it's probably overkill anyway, I know it's not exactly the same thing but heck my truck transmission gets flushed every 30k, that's a lot of hours. After reading some of the posts on here I was expecting to find big chunks of metal lying in the drain pan.:) Maybe some people don't figure out what the clutch is for until after 50 hours;)
/ changing HST fluid #9
Mine's hydro, found shavings in the fluid and screen at 50 hrs. Just for giggles, I did it again at 100 and perfectly clean. So for me it was worth it.
Gear tractors may behave differently in this mainenance, don't know.
/ changing HST fluid #10
Doesn't get much better than this.
Kubota BX Service
The B7800 has a strainer screen and the fastener head is 26mm in size.
Mines hydro too. I was referring to using the clutch for the ratio (L,M,H) change. Oh well, I'm just crabbing because I didn't feel like spending 120 bucks this weekend and crawling around on the floor with messy oil all over the place:(
/ changing HST fluid #12
hard to get to fillers, gotta love those.
totally understand the shoulder shrug. but an industry wide proclamation based on one anecdotal experience probably isn't the best bet.
most machinery has break in periods for very specific reasons.
i mean hey, it's a great thing how clean yours was and a testament to the quality of product and maybe you got one of the better ones off the line?
in a way it's not really ideal to "only change fluids when visible, particulate matter is present".
I was just going to let this go but - I don't like your condescending attitude in telling me what is a good bet and what isn't
I think I was pretty clear in stating that my post was an "unprofessional opinion and just my experience. I wouldn't call it an "industry wide proclamation" by any stretch of the imagination. I'm simply stating what I saw in my experience and what I am going to do based on that experience and the supposedly incorrect manual and let everyone form their own opinions base on their experience and information. I never stated that I was going to change fluids when visible, particulate matter is present -those are your words - how the **** would you know unless you drained it anyway? I said I was going to change it at the original 400 hours stated.
I actually thought the filters were pretty easy to access once your lying under the thing. Is that an "industry wide proclamation"?
/ changing HST fluid #14
I'm with you on that. Not a fun activity, the most frustrating part for me is that my drain pan won't fit between the tires. Have to jack it up 8" or so. Minor complaint. The filter is a little tougher with the MMM mounted.
Now that you're done you can forget about it for a while...:D
/ changing HST fluid #16
So for me it was worth it..
Leaving cuttings in there for 50 hours is plenty long enough .
No need to leave them in there for another 2 or 3 hundred hours.
/ changing HST fluid #17
I think the main reasons that Kubota recommends changing the hydraulic fluid at 50 hours in the BX and 400 hours in the L series is because:
The BX has a small $9 filter and a just a transmission screen and only holds about 2 gallons of fluid.
The L series has a large $40 hydraulic filter and a large $60 HST filter and holds about 13 gallons of fluid.
There is more fluid and it is much better filtered in the L series thus requiring changes less often the first time.
/ changing HST fluid #18
TallyHo, I'll bet you dollars to donuts part of this manual change is to satisfy environmental regulations in US.
Tim, go to Lowes and buy the black, flat-sided bucket. $5 and it fits PERFECT under a BX.
Bstrom, relax. You're not getting flamed.
Yet. :D
/ changing HST fluid #19
Yet. :D
Thanks...I'll do that. "Shimming" it on 6x6's+2x6's isn't fun.
/ changing HST fluid #20
What L series is this please?
